Unread 04-04-17, 10:28 PM   #151
Jonas_R
Denmark
Jonas_R's Avatar
Originally Posted by Macchris View Post
i like this job ! well done ! i have a 7A too to convert, but dunno where i can find a PC file for the worker
or maybe i must bring an AAN head cylinder for example.
I brought my aby head as a reference, so can't help with a file.
Jonas_R is offline   Post Tools
Unread 04-04-17, 10:35 PM   #152
Macchris
France
Macchris's Avatar
thanks, i think i'll do the same, must find a bad head cylinder (want to do a 20V T head cylinder in advance)
http://www.s2forum.com/forum/image.php?type=sigpic&userid=16039&dateline=144595  2774
Macchris is offline   Post Tools
Unread 08-04-17, 07:24 PM   #153
Jonas_R
Denmark
Jonas_R's Avatar
Slowly getting there
Slowly progress getting the car back to gether.
Gearbox and engine mounts all in place.
Heatshield back on - damn that was expensive.
Hose for the servo is back on and refurbished
Turbo, oil & water hoses in place and also got the WG back on. But the turbo from Iroz Motorsport was turn 180 degress the wrong way on the compressor side. A bit annoying to be honest.
Unread 26-04-17, 07:42 PM   #154
Jonas_R
Denmark
Jonas_R's Avatar
Small progress
Got the intake on, the afterrun pump, changed water sensor and oil sensors.
Unread 13-05-17, 09:41 PM   #155
Jonas_R
Denmark
Jonas_R's Avatar
Getting there
So my friend made me a new oil cooler bracket in stainless steel so it wont rust like the old one:
New oil cooler and bracket fitted:
Also got my new aircon rad installed, the old one was completly broken and also changed all the o-rings while I was at it:
Aux rad, crossmember, travers, boost hoses and Wagner IC back on. But had to cut and reweld the wagner IC bracket was way off.
Installed new o-ring but it was leaking so had to install the Marc O.
And finally a new Forge DV-008
So car should be stared on monday, just need to fix the following:
  • Exhaust+downpipe
  • Engine Oil, Coolant, Steering fluid
  • Bleed clutch
  • Airbox
  • Pump oil in the turbo
  • Last boost hoses and boost pipe
  • Mount EGT, Wideband and IAT sensor
  • Front bumper
Unread 13-05-17, 09:55 PM   #156
sailaz
United Nations
sailaz's Avatar
... at first moment I thought from where you've got a photo of mine oil cooler bracket
P.S. I mean that the one on the left looks exactly like mine, but the one on the right is a result of precise job
sailaz is offline   Post Tools
Unread 13-05-17, 09:56 PM   #157
rxl
Home Country - Lithuania Current Country - Germany
Can your friend make another one?
rxl is offline   Post Tools
Unread 13-05-17, 10:01 PM   #158
Jonas_R
Denmark
Jonas_R's Avatar
I can ask but I think it will be expensive, he was complaining a lot about the time spent
Unread 13-05-17, 10:03 PM   #159
rxl
Ask him and write me a pm on that. The work looks nice like a stock one
Unread 15-05-17, 08:32 PM   #160
Jonas_R
Denmark
Jonas_R's Avatar
Fitting of downpipe
So no start today, to much time went on make the downpipe fit.
First fitment -> Downpipe was hitting the gearbox so it had to be cut at the first bend and realigned.
Also had to cut of the flex to weld on a longer piece so there was room for the Wideband sensor and a little bracket to bolt the downpipe to the gearbox:
Finished downpipe with bongs for egt, lambda and wideband:
Unread 15-05-17, 09:18 PM   #161
s0_big
Sweden
s0_big's Avatar
Nice
Nice work! Looking good. Maybe your'e going to Malmö some time during the summer? A lot of danish people is comming and drive at our 1/8 mile drag track.
s0_big is offline   Post Tools
