Unread 30-10-14, 04:43 AM   #31
Jonas_R
Denmark
Jonas_R's Avatar
Billet wheel installed instead of stock.
Taking it to the MOT today, fingers crossed
Jonas_R is offline   Post Tools
Unread 24-11-14, 06:34 AM   #32
Jonas_R
Denmark
Jonas_R's Avatar
Update on the project
So it passed the MOT without problem.
Did some minor repaires this weekend.
Discovered that the previous owner had blocked off the PCV system. No catch or anything just at plug at the MAF hose.
So new pipe from audi and back to oem for the time being.
Previous owner had also ****ed the oil drain plug and welded on it. But instead of changing it he reused with a washer and then over thighten it. I had to use a 1/2 meter pipe rench to get it loose. Bloddy annoying.
Also got some new calipers from germany, they need a little cleaning but otherwise fine.
Not sure if I should paint them black or keep them red?
Unread 24-11-14, 08:32 AM   #33
tscheel
Denmark
tscheel's Avatar
Maybe this helps deciding.
Cheers, Torben
'94 B4 Avant S2
tscheel is offline   Post Tools
Unread 24-11-14, 08:37 AM   #34
irishs2
Ireland
irishs2's Avatar
If its a sleeper they should be black
Eric
95 S2 Avant under rebuild.
irishs2 is offline   Post Tools
Unread 24-11-14, 08:41 AM   #35
Jonas_R
Denmark
Jonas_R's Avatar
Yeah I think black is the way to go with audi rings as logo instead of porsche.
Torben: are does your calipers? Are they power coated or just painted with normal caliper paint?
Unread 24-11-14, 08:45 AM   #36
tscheel
Denmark
tscheel's Avatar
Yes, The coating is original - it looks more anodised than painted. The "PORSCHE" text earned me another trip to MOT after fiddeling with the old G60's
Cheers, Torben
'94 B4 Avant S2
Unread 24-11-14, 08:54 AM   #37
Jonas_R
Denmark
Jonas_R's Avatar
Ok I think I will try the Foliatec matt black caliper paint.
Unread 24-11-14, 12:42 PM   #38
europeanme
europeanme's Avatar
red all the way!...
very lucky with your crank pulley....how that has happened is anyones guess...
europeanme is offline   Post Tools
Unread 24-11-14, 05:05 PM   #39
Jonas_R
Denmark
Jonas_R's Avatar
Originally Posted by europeanme View Post
red all the way!...
I think it will be black all the way
Regarding crank pulley, then my guess is previous owner thighten it using a air gun. I mean lots of the stuff done on the car seems half assed to be honest.
I mean who welds on a stud on the oil drain plug and then reuses it. A new one is 2£.
Also when I bought the car no rear wiper, no electrical mirrors and no heated rear window. I then check out the fuse box, and the fuses are missing.
Unread 22-12-14, 11:26 AM   #40
Jonas_R
Denmark
Jonas_R's Avatar
So I have modified my valve cover to fit my new tfsi coil cover.
I wanted to powder coat the valve cover black to match the other cover, but my painter is delaying it all the time.
So should I keep the valve cover stock or paint it black?
Unread 27-01-15, 06:45 PM   #41
Jonas_R
Denmark
Jonas_R's Avatar
So decided to keep the valve cover OEM.
Unread 27-01-15, 07:02 PM   #42
Jonas_R
Denmark
Jonas_R's Avatar
So painted my calipers black with paint from Foliatec, but the results was not really that great.
So I'm blasting them and changing seals and pistons and I think I will get my friend who spray paints cars to paint them black.
Unread 25-02-15, 12:46 PM   #43
Jonas_R
Denmark
Jonas_R's Avatar
New valve cover installed
So finally got some time to install Error404's TFSI harness, my TFSi coils and new valve cover.
A small snag was that I did not tell Error that my coils all point the same way but not that big of a deal.
Some pictures:
Unread 25-02-15, 12:51 PM   #44
irishs2
Ireland
irishs2's Avatar
Nice. I like that coil cover, but you need to mill the cam cover for it to fit.
Eric
Unread 25-02-15, 12:53 PM   #45
Jonas_R
Denmark
Jonas_R's Avatar
Yup it needs some milling, but that is easily done.
