Unread 15-05-15, 08:20 AM   #61
quattrostyle
Netherlands
quattrostyle's Avatar
A black 90 center plate would be nice but I think it looks good as it is now.
quattrostyle is offline   Post Tools
Unread 25-05-15, 08:56 PM   #62
Jonas_R
Denmark
Jonas_R's Avatar
996 brake upgrade - Done
Did the front brakes today with 996 calipers and A8 323x30 Dics.
Custom RS2 brackets painted black (same color as the calipers)
Finished result.
I need to do the rear brakes as well with new pads and dics. And I want to convert it to vacuum brake booster.
Jonas_R is offline   Post Tools
Unread 26-05-15, 12:26 AM   #63
macspring
Originally Posted by Jonas_R View Post
Maybe consider new rims (& tyres also).
Just sayin.......
Unread 26-05-15, 04:39 AM   #64
Jonas_R
Denmark
Jonas_R's Avatar
I got a set of Audi s6 rims that I will use.
However they need to be sanded and powder coated.
To many projects and not enough time
Tires are actually fine.
Unread 26-05-15, 07:17 AM   #65
macspring
I share your dilemma also.
Nice work.
Best wishes.
Unread 26-05-15, 07:39 AM   #66
Jonas_R
Denmark
Jonas_R's Avatar
But i do agree that the Black rims Are ugly and scratched ��
Unread 31-05-16, 08:09 PM   #67
Jonas_R
Denmark
Jonas_R's Avatar
Suspension almost done
Finally got some time to work on the S2.
New shock absorbers, spring and upper strut bearings fitted.
Before:
Work in progress:
Did have some problems with the thread on the strut. The new bilstein shocks use much more of the thread then the old stock shocks. So took a while to clean the thread and get it usable, but worked out ok in the end.
After:
Started on the rear shock absorbers, but ran into problem with rear calipers that where very rusty and not working at all. Also the bushings in the upper transverse where completly destroyed. So new calipers and then new bushings and I will balst and count the transverse.
Rear strut assembled:
Unread 02-06-16, 07:49 PM   #68
M_GORDON
Home Country - Thailand Current Country - Antarctica
M_GORDON's Avatar
Before:
After:
Lowered??
I can`t appreciate correctly
M_GORDON is offline   Post Tools
Unread 02-06-16, 07:51 PM   #69
Jonas_R
Denmark
Jonas_R's Avatar
Yeah should be lowered 30/30 but not sure that actually is the case.
Unread 04-06-16, 03:24 PM   #70
Jonas_R
Denmark
Jonas_R's Avatar
Got the rear strut fitting and then I blasted, painted and fitting new bushing for the the upper arm (don't know the english word).
However I think it sits to high on the new H&R springs will get a picture when it has settled. Anybody have measurements of the height from the ground to the top of the wheel arch, front and rear?
Also got my K24R LHD catch tank party mounted, hoping to get the rest done next time I have a couple of hours to spare.
Unread 04-06-16, 04:37 PM   #71
joonatan96
Finland
joonatan96's Avatar
Looks nice
joonatan96 is offline   Post Tools
Unread 05-06-16, 11:07 AM   #72
M_GORDON
M_GORDON's Avatar
We must wait for it.
I want know how much they low in the reality.
Thanks a lot.
Unread 05-06-16, 04:13 PM   #73
maiks
Estonia
maiks's Avatar
[/quote]
This is not a good place for catch tank.. When it's fill then it may leak to downpipe and cause fire.
maiks is offline   Post Tools
Unread 05-06-16, 05:21 PM   #74
Jonas_R
Denmark
Jonas_R's Avatar
I can't see how it will leak since it is a closed system and i had something similar on my coupe for years.
So I'm not worried to be honest
Unread 10-06-16, 10:50 AM   #75
kinaputt
Norway
This catch tank could burn down your whole car if a hose comes loose.
kinaputt is offline   Post Tools
