Unread 18-05-17, 05:31 PM   #406
SA BOY
Home Country - South Africa Current Country - United Kingdom
WOW Lovely car and well done for sticking with it.
SA BOY is offline   Post Tools
Unread 19-05-17, 10:44 PM   #407
LeafBox
Sweden
LeafBox's Avatar
Sticking with it was the hardest part
But hey guys, I got a problem.
I swappet my 034 top mounts to Meyle HD and there's still a terrible amount of wiggleroom. The Meyle mounts is a tiiiiny bit better, but it's still clunk-city.
Is there like a bigger mount or something from another car that has a thighter fit?
LeafBox is offline   Post Tools
Unread 20-05-17, 07:19 AM   #408
quattrostyle
Netherlands
quattrostyle's Avatar
Surely the Meyle mounts are not THE solution but it should be good for a while. There must be something wrong in your setup?
quattrostyle is offline   Post Tools
Unread 20-05-17, 07:36 AM   #409
LeafBox
Sweden
LeafBox's Avatar
I mean yeah. Something is clearly wrong
I just don't know why, everything is mounted correctly, brand new parts, and I can still move the top mounts by hand when they're up in the tower?
I feel like they should be a couple mm bigger in diameter
Unread 20-05-17, 11:46 AM   #410
quattrostyle
Netherlands
Really weird, it can't be mounted correctly if you can move the topmounts by hand WHEN the car is on it's wheels (not sure how to check that since there will be no space to get your hand in there.
Think it's normal when the wheel is off the ground, I'll check with my car in a minute.
Unread 20-05-17, 01:56 PM   #411
LeafBox
Sweden
LeafBox's Avatar
I mean I can move them with the wheel off the ground. Up&Down is normal, but side to side?
I can TILT the whole struts a couple of mm...
Unread 20-05-17, 05:19 PM   #412
Typ89
Netherlands
Typ89's Avatar
How much is a couple millimeters? Up to about 3mm should be fine.
Typ89 is offline   Post Tools
Unread 21-05-17, 01:27 PM   #413
LeafBox
Sweden
LeafBox's Avatar
I figured it out!
I went by the car earlier to take a video for you guys so you could get a better look.
And while I was watching the video back I noticed something that I couldn't see before.
Long story short, the big hollow nut that holds the shock down in the strut had somehow come loose, so it wasn't the top mount making the knocking (I mean, they're still loose as hell, but not enough to make a sound), but the whole damn shock jumping around inside the strut.
I'm pretty sure I pulled it nice and snug, so I don't know if I just messed up or if they came undone somehow. I'll keep an eye on them...
Glad to have that sorted, the car feels much more 'proper' when there isn't a bunch of strange sounds going on.
I also shimmed the WG-spring, so now I'm reaching the correct boost preassure.
I guess that the 20vt WG is different, because I didn't have the supposed hidden adjuster screw in the lid.
She pulls real nice and I'm gonna look into getting her on a dyno sometime during the season.
Unread 23-05-17, 07:12 PM   #414
quattrostyle
Netherlands
Cool
Did check on my car on saturday and I can't move the top mount with the wheels of the ground.
