Unread 05-04-15, 04:12 PM   #16
Morris400
Canada
Morris400's Avatar
The N80 is run to the Intake manifold already. It's attached to the rubber "T" under the manifold. And I think you could get away with the filter. A buddy of mine ran a filter like that but with the Oem pcv system. When deleting all the valves and the catch can you would be safe to keep it attached to the inlet as nothing should get past the catch can.
Morris400 is offline   Post Tools
Unread 10-04-15, 07:33 AM   #17
RichLV
Latvia
RichLV's Avatar
Change of plans, gonna leave the stock system intact, just replace the valves with ones from 034 motorsport, replace hoses with silicon equivalents and throw a catch can between cam cover and pressure valve.
Is it a worthy investment to go for a MAFless chip? They are twice the price of a regular one.
RichLV is offline   Post Tools
Unread 13-04-15, 05:10 PM   #18
RichLV
Latvia
RichLV's Avatar
Swapped for summer boots!
Unread 13-04-15, 08:59 PM   #19
RichLV
Latvia
RichLV's Avatar
So I could use some info on mods. The target is about 300-350 HP, on stock internals. What should be done to achieve that target besides mapping? Power upgrades will come after full engine rebuild. Ebay silicon hoses will be bought as well.
Apprieciate the info!
Unread 13-04-15, 10:08 PM   #20
macspring
Don't be tempted to use the little metal 034 valve in the PCV system. It is my understanding that they do not work as well as a new oem one.
Others may know more.
But maybe play it safe with the oem one in the meantime.
Regards.
Unread 13-04-15, 10:26 PM   #21
RichLV
Latvia
RichLV's Avatar
Everyone keeps telling me that all the valves from 034 are not worth it. Are they that bad?
Unread 13-04-15, 10:28 PM   #22
hunker7
hunker7's Avatar
Audi has done pretty good job on setup on these cars, most things are not worth upgrading unless you're going some silly power.
'93 Audi UrS4 Avant LPG
hunker7 is offline   Post Tools
Unread 13-04-15, 10:33 PM   #23
RichLV
Latvia
RichLV's Avatar
So at my power target I can leave plastic OEM valves? Just throw in some silicon hoses?
Unread 13-04-15, 10:37 PM   #24
hunker7
hunker7's Avatar
I'm sure you can (correct me if I'm wrong), and i think even OEM hoses are good for 300-350, I mean that's RS2 power.
Unread 14-04-15, 06:15 PM   #25
Morris400
Canada
Morris400's Avatar
I kept all Oem plastic valves and their fine. The Oem boost hoses however did not hold up to chipped ecu boost. The lower intercooler hose blew right open at WOT. And the upper intercooler although still intact and installed has started to show signs of cracking.
Keep Oem pcv valves
Silicone hoses. EBay is fine that's what I went with.
Unread 14-04-15, 07:58 PM   #26
RichLV
Latvia
RichLV's Avatar
What about the PCV silicon hoses from 034? Are they any good?
Unread 14-04-15, 10:09 PM   #27
macspring
Mine are fine, my car has lead an easy life though.
Was the inside of the pipe and intercooler neck thoroughly degreased with a solvent ?
While uprated hoses may be the long term answer, it may allow the op to use his oem hoses for the time being.
Unread 15-04-15, 12:47 AM   #28
Morris400
Canada
Morris400's Avatar
My lower intercooler hose split in the ribs. I had 234k km when it went and the hose was probably the one from 94. I know the oem hoses are ok but when mine went I had to wrap the hose in duct tape and stay out of boost for weeks until new ones arrived. Really a pain in the ***.
As for the silicone Pcv hoses. It will kinda improve the engine bay look but there pretty hidden. Again for the cost vs function...if it ain't broke it don't need fixin. Just my 2cents. I kept all oem hoses minus the 3xmm one that comes off the block which was leaking on mine. I replaced that with some silicone hose from a hardware store here.
Unread 15-04-15, 07:10 AM   #29
RichLV
Latvia
RichLV's Avatar
I just realized that I'm missing the PCV one-way bleed valve. It's just not there, simple hose is taking it's place.
Unread 15-04-15, 11:58 AM   #30
Morris400
Canada
Morris400's Avatar
The valve is conceled in 2 small hoses. It's not visable per say untill you remove the part connecting to the bottom of the T hose to the hard line.
http://12v.org/urs/PCVStuff3a.jpg
This link.shows the position of the one way valve. If yours looks like this then it's probally there.
Tags
latvia , urs4 lv
