Unread 20-06-15, 07:56 PM   #61
RichLV
Latvia
RichLV's Avatar
Basically I've ordered OEM AAN plugs - 101000016AA. Should be F5DP0R's AFAIK. We'll see when I get them.
RichLV is offline   Post Tools
Unread 30-06-15, 07:10 PM   #62
RichLV
Latvia
RichLV's Avatar
Got the plugs and yeah, they are F5DP0R's
Swapped them in and roll on!
Besides plugs, did some prop shaft restoration work. My propshaft was ringing when standing and revving more than 3500 rpm. Got the parts described in multiple threads here - Ford Scorpio CV joints (LPR KAR801) and BMW central bearing. Unfortunately the bearing was a no go, looks like it can only be put on S2's. But examining the original bearing I found a part number - 4A0521113A. Checking that number in parts stores I found a single bearing - TED-GUM 00054970. Dunno what Ted Gum is, but better a new bearing than a broken one. Mine was kinda OK, so we decided to leave it for now.
New joint in place. Joints were perfect for the shaft, no unnecessary movement when assembled. The old front one was completely broken, it was rattling and moving from side to side.
Also changed gearbox's tail gasket, between propshaft and differential.
Unread 01-07-15, 06:28 PM   #63
RichLV
Latvia
RichLV's Avatar
I have a 6-speed box from a similar S4 withing my grasp and I'm thinking is it a straight swap? I have a 5-speed CBD, and that one is 6-speed CBL. Has anyone done this before? What about linkage and shifter?
Unread 13-07-15, 06:18 PM   #64
RichLV
Latvia
RichLV's Avatar
Long time no type eh?
So, my ignition lock broke. Key just went full circle without any life signs. Pretty standard issue on these cars. So I took the lock off and started it with a screwdriver. After some of those starts (It's my daily car, I need it) the ignition contactswitch jammed in starter position and burned down my starter. Epic fail for me.
So I started fixing it. Got starter from 2.3 AAR, and since the ignition lock only can be put from non-adjustable steering column, I thought f*ck it, I'm swapping the adjustable column in. And everything that goes with it. Since I'm changing my key, I swapped all locks as well.
So what was done:
- New locks all around (front doors, trunk)
- Adjustable steering column assembled with ignition lock.
- S6 C4 V8 dash installed (dash modified - clock removed, oil pressure in place)
- All attributes around steering column from A6, S6 air bag steering wheel.
Some considerable mods had to be done to do all that.
Steering wheel switch clamps had to be adjusted and some pins swapped to different spots, switches from S6 cannot be connected to 100/UrS4 clamps.
Installed oil pressure gauge from my old UrS4 dash. Pretty straight forward.
Relay trick to stop the annoying ABS error.
Phase 1 of interior changes complete. Everything works. Got a consumption gauge instead of boost gauge just as I wanted. Dashboard recoded to 5-cyl turbo. Gotta do something with dashboard illumination, it's too dark, and oil pressure gauge does not match color with the rest, it's orange. Even check engine light works.
Unread 13-07-15, 07:02 PM   #65
hunker7
hunker7's Avatar
More info on this? I would much rather have that over boost gauge.
'93 Audi UrS4 Avant LPG
hunker7 is offline   Post Tools
Unread 13-07-15, 07:50 PM   #66
RichLV
Latvia
RichLV's Avatar
There's nothing to it. Get a V8 S6 C4 dashboard and just swap it in. Only things that need to be done are diagnostics connection to dash, ABS light workaround & recode the dash to 5-cyl turbo. Consumption works straight away, all the pins are present. Gotta love Audi for universality (or laziness to make another set of wiring ).
Unread 13-07-15, 07:55 PM   #67
hunker7
hunker7's Avatar
Might have to try at some point I know it can save loads on fuel when you see "current fuel consumption"
Unread 18-07-15, 03:31 PM   #68
RichLV
Latvia
RichLV's Avatar
Finally got that 7A valve cover installed.
Setup is the same as everyone's, only the back end is my own design
Unread 15-08-15, 03:35 PM   #69
RichLV
Latvia
RichLV's Avatar
Some updates. Got major misfiring issue right after fitting 7A cover. While fitting the cover, fixed all intake leaks by replacing all hoses with silicone, turbo finally blows where it should. Right after that the car started misfiring horribly, and very violently. Was battling with it for 3 weeks until found out the cause. In the process we swapped everything that is possible to swap, to no avail. At the last moment when nothing was left to swap I decided to my old spark plugs in. All problems were miraculously gone the moment I took out F5DP0R's. Big thanks to Dave for holding with me during this time.
Spent 2 days trying to choose spark plugs. Chose FR5DTC, but not Bosch, don't want to drive with Bosch plugs. I picked NGK alternative - BCPR7ET. Running good so far.
Got a new G40, G28 and G4 sensors in the process of debugging the misfire. All FACET made.
Started tidying the engine bay after that. Last of the silicone arrived, final hose replaced.
Gonna hunt missing plastic bits from the engine bay - Airbox/MAF cover, firewall connection cap.
Some wastegate porn. Replaced the old and worn out studs with these 6 strenghtened allen heads. Resprayed the WG cap with thermal matte black color.
Next in the list:
1. another set of headlights, mine are in pretty bad shape. I'm going to get a set of lights in good shape from S6 and swap my glass in.
2. rear sway bar assembly. I do not have it and want to get it. I'll get poly crossmember bushes from Apikol before installing it.
3. gauges. Already installed turbo boost gauge, still need fuel pressure and air/fuel ratio gauge.
Unread 15-08-15, 03:48 PM   #70
UrS4boy
Canada
It was "fun" trying to help you with that problem. I only wish the first suggestion I would have made was the plugs. However because the F5DP0R plugs were quite new, I did not suspect them as the ultimate problem. I think I did say check the plugs but I was thinking that maybe they weren't tight in the head. Oh well, fixed now.
Question: Is this the 16V 4 cylinder VW/Audi engine distributor Hall sender that you used as your "Tuna Can" AAN G40 cam sender:
UrS4boy is offline   Post Tools
Unread 15-08-15, 04:05 PM   #71
RichLV
Latvia
RichLV's Avatar
Well, as you know, simplest solutions are usually the last ones.
Yes, this is the one. I picked it from Golf 2 catalogue - 1.8 16V (PL engine code). Part number - 030 905 065. Basically any similar Hall will do, be it from Audi 80, 90 etc., any distributor device. Had an adventure with it later on though. We were in the process of getting to a lake for a swim when CEL came on. I stopped, and shut the engine down, which was a mistake. Surprise surprise, the car did not start, no ignition at all. The G40 was my first thought. Friend came and dragged me home. VCDS connected and fault found - Mechanical Malfunction. It turns that the pin, which holds the gear of the dizzy attached to shaft was wobbly and fell out during the drive, displacing the timing mark of the dizzy. Good thing that it did not bounce deeper under the cover, stayed in the dizzy gear camera. Took it out and threw it away. Installed a new gear pin and problem solved in 10 minutes.
Still have 00561 fault though, the idle one - Mixture Adaptation (Add) Exceeded. Can't figure out what could be the cause. All the hoses are new and silicone. I suspect that lower right turbo nut might be the case since I can't tighten it up. Or the wastegate flextube to downpipe connection since I do not have a gasket there, sealed it with exhaust sealant for now.
Unread 15-08-15, 04:57 PM   #72
UrS4boy
Canada
Hmm....030 905 065 comes up as, this, which doesn't look as right as 030905065B below
030905065B comes up as:
Unread 15-08-15, 05:01 PM   #73
RichLV
Latvia
RichLV's Avatar
Strange. Our shops show both types under 030 905 065. I just picked the one which looks like OEM.
Unread 15-08-15, 05:06 PM   #74
UrS4boy
Canada
??? The actual senders in those two designs are a 180 deg out. Not sure how that would be corrected.
Unread 15-08-15, 05:13 PM   #75
RichLV
Latvia
RichLV's Avatar
For some unknown reason, they both work equally good. Had this thing going with my old A80, tried both orientations. Both worked without any issue.
Tags
latvia , urs4 lv
