Unread 05-09-16, 09:59 PM   #16
momento1
Australia
momento1's Avatar
Originally Posted by macspring View Post
You were obviously right to rebore and use new pistons at this level of preparation / power.
While I'm in there etc. You only want to do it once.
What is the car to be used for as it is too stiff and powerful to daily ?
Maybe you should consider keep all your old parts and making up a spare engine to have on the shelf ?
Nothing is getting for S cars is 'common as muck' these days, especially where you're based. Just a suggestion.
Thanks for sharing.
Car is not going to be a daily driver. Only a weekend car and occasional track and drag use
Main reason i am going over and above with everything is so it gives the engine room to move in case i want to chase more power.
But i think i should be very happy with the result once finished
Current:
1993 Audi S2 Kingfisher Blue - "Run-in" tune = 290kw atw
Past:
2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
2001 Audi S3 Silver - 169kw+ atw
momento1 is online now   Post Tools
Unread 01-10-16, 04:58 AM   #17
momento1
Australia
momento1's Avatar
Just a quick update and some more photos.
Basically nothing has happened too quickly as im still waiting on when i can get my hands on an SQ manifold.
Rods, pistons, crank, and main girdle sealed, spaced and installed.
Current:
Past:
Unread 01-10-16, 09:05 AM   #18
Error404
Moderator
Error404's Avatar
Coming together nicely
You have a good stock of racefuel there by the looks
Unread 01-10-16, 02:59 PM   #19
momento1
Australia
momento1's Avatar
Lol thats my mechanics race fuel.
He has a few drag cars. 2 of them run in the 7sec bracket
Current:
Past:
Unread 07-10-16, 11:30 PM   #20
momento1
Australia
momento1's Avatar
Project fast S2 to faster S2 - Australian Edition
Checking and adjusting new catcam timing.
Sprockets had no timing marks at all
Current:
Past:
Unread 08-10-16, 02:43 PM   #21
((A.V.))mk-1
United States
Really great build. I love the color. What is the paint code? Any more pictures of this car in its natural habitat?
((A.V.))mk-1 is offline   Post Tools
Unread 09-10-16, 02:22 AM   #22
momento1
Australia
momento1's Avatar
Paint code is LY5T
Kingfisher (Pelican) Blue metallic
As you can see ive changed wheels a few times.
Current:
Past:
Unread 12-10-16, 09:05 PM   #23
((A.V.))mk-1
United States
I really love the color, it looks so different in each light setting.
My pearl clone is past due for a spray... Maybe a color change is in its future.
Unread 27-10-16, 10:24 PM   #24
momento1
Australia
momento1's Avatar
Good news!
Engine is in and we did a test fit on my existing evo manifold and the turbo fits perfectly!!
So i dont have to wait for another manifold!!!
Also with the 10mm girdle plate i was worried i would clear the subframe cause the sump sits lower bit it clears everything nicely.
Now just need to bolt all the bits on and get her running.
Also in other news i pulled out the aircon cause it keeps getting in the way for the reverse intake!
Should run cooler now cause the radiator isnt blocked
Hope to have it running by end of next week!!
So happy that everything is going to plan!!!
Current:
Past:
Unread 28-10-16, 02:33 AM   #25
20vTurbo
Home Country - England Current Country - Australia
20vTurbo's Avatar
Looking good
'94 S2 (RS2+ spec. Tarmac Rally Car)
S2QuattroMotorsport
20vTurbo is offline   Post Tools
Unread 08-11-16, 12:48 AM   #26
momento1
Australia
momento1's Avatar
So this is where im at...
looks mean!!
And plumbing up the wastegate. Im also going to have a screamer pipe made up so i can switch around for "off-road" use.
Current:
Past:
Unread 01-12-16, 01:36 AM   #27
momento1
Australia
momento1's Avatar
so just another update.
the car has been back with me for a week or so i think now. Havent driven it much. Basically its on a run-in tune so its a real lag-monster at the moment with boost not coming on until approx 4800 and rev limit only at 6500rpm...
Good news is that the "run-in" tune is a measly 290kw at the wheels at 18-19psi though....
So i cannot wait to get her back in for the final tune..
Rev limiter will be set at 9000rpm for a nice full power band.
Not sure what boost settings i will run as yet (see what it can do comfortably) but im thinking around 24-25psi low boost setting should be around 350kw and a high boost of about 35psi should get me close to my goal of 450kw (or 600hp) at the wheels
Failing that the new Garrett GEN 2 GTX3582r turbo just got released and its a similar sized turbo but capable of an extra 100hp
time will tell
Current:
Past:
Unread 01-12-16, 04:25 AM   #28
20vTurbo
20vTurbo's Avatar
Monster!
Sent from my iPad using Tapatalk
S2QuattroMotorsport
Unread 07-12-16, 05:44 AM   #29
momento1
Australia
momento1's Avatar
The only size filter i can fit!!
And even then i had to hack 10mm off the back of the pod to get it in there
Current:
Past:
Unread 07-12-16, 08:06 AM   #30
SteveH
Moderator
SteveH's Avatar
You might want to try routing the filter away from the exh manifold. Easier said than done, however, it will stop you sucking in a load of very hot air.
91 Modded 3B
14 A6 Avant Black Edition
SteveH is offline   Post Tools
