Unread 06-04-16, 01:43 PM   #31
Spyform
Estonia
Spyform's Avatar
Originally Posted by Greg_S View Post
Loving the bus. Should stop really well with the new brake setup. Will the peddle travel increase with the 6 pistons on the front?
I can say, until all gather, I will understand how it work, then we will see what changes needed
Audi S6 C4 2.2T Quattro 1997, full rebuild....
Audi A5 Sportback V6 2.7 TDI 2011
Volkswagen Phaeton V6 3.0 TDI 2009
Spyform is offline   Post Tools
Unread 06-04-16, 03:46 PM   #32
popdemonic
Thailand
I didn't feel any further pedal travel on 6pot cayenne or panamera on my car.our mc is 25mm.it's big enough to
Inject the brake fluid to those 6 pot calipers.
one of a few I5 from Asia.
popdemonic is offline   Post Tools
Unread 06-04-16, 03:54 PM   #33
Spyform
Estonia
Spyform's Avatar
that is good news for my future plans
Unread 07-04-16, 07:08 AM   #34
Cordoba16vt
Bulgaria
Softer and more progressive pedal feel with 17Z Brembos on 330x28 Mercedes Sport Discs .
Feels like twice the braking power
Cordoba16vt is offline   Post Tools
Unread 08-04-16, 08:13 AM   #35
Spyform
Estonia
Spyform's Avatar
Got my OE carbon trim set, really want it all the time
bough it from Codman thnx
Unread 09-04-16, 08:27 PM   #36
Spyform
Estonia
Spyform's Avatar
Today got my URS6 HP2 struts, yeaaah
Unread 12-04-16, 07:04 PM   #37
Spyform
Estonia
Spyform's Avatar
Hello guys!
Today I received a parcel from Finland, there was adapters for back calipers, so i can now use 310mm brake disc, and a AAN sump baffle plate. Thank you very much Thuppu!!
Last pic is how Estonian beavers working out
Unread 14-04-16, 08:12 AM   #38
Spyform
Estonia
Spyform's Avatar
Нesterday began to disassemble the rear axle, unscrew everything very easy, so strange.
And then wash the mad German, and even burn rubber... to much torque
Unread 14-04-16, 07:28 PM   #39
Newmember
Estonia
Now I know who did this burn out and it seems that you live near by me. Nice project, good luck with it!! Hope to see her next summer on the roads!
Newmember is offline   Post Tools
Unread 15-04-16, 03:11 PM   #40
Spyform
Estonia
Spyform's Avatar
hahahah it is cool that u live near me
Unread 15-04-16, 05:09 PM   #41
Newmember
Estonia
It seems that our world is really small, no one can hide
Unread 23-04-16, 06:28 AM   #42
Spyform
Estonia
Spyform's Avatar
Tomorrow engine will be out and it goes on it way to full rebuild
Unread 24-04-16, 03:49 PM   #43
Spyform
Estonia
Spyform's Avatar
Soo hello guys...
So it happened, the engine is removed, disassembled, and one of these days will be checked the crankshaft, at the moment it is known that I was very lucky, the crankshaft have never been repaired, pistons are factory to the minimum amount, the walls of the cylinder without scoring and visual (on the finger) also perfectly aligned !!! pistons are also in excellent condition, although at the lower pit under the ring there is a small gap in the 0.05 mm. will be the new piston and connecting rods
Head is with 2 little cracks, but nothing serious, everything will go. .
A unit, all clearly in the oilsump were some fragments of chain apparently collapsed, but the pump was not hit. A tray is not broken.
A couple of photos of the process.
Now in the garage and in the engine bay there are a lot of space, i can remove the frame and the gearbox, clean it all and paint it after ....
Many thanx to Newmember for helping to remove the engine... thnx man
Unread 24-04-16, 07:41 PM   #44
Newmember
Estonia
No problem bro! just ask and I will help you anytime, this car is worth it
Unread 24-04-16, 07:48 PM   #45
Spyform
Estonia
Spyform's Avatar
man u are real bro!!!
