Unread 24-02-17, 07:33 PM   #1
Hammu
Finland
I5 B5 avant quattro
Finnish users probably already know this, but i thought to share here also.
I'm building 5cyl b5 avant q, base model is 1996 2.8 30v.
I'm going to quickly explain last six months and update more regularly because translate work for would be pain in the @$$ to do.
Whole story can be found from audifinns forum, sadly finnish text but correct timeline on pictures http://www.audiclub.fi/audifinns/sho...d.php?t=154743
All of the pictures https://hammu.kuvat.fi/kuvat/I5B5/
Other random project madness from instagram https://www.instagram.com/thehammu/
Engine specs:
AAN block
JE pistons with hd pins, compession ratio 9.8:1
H-profile rods
7a ported head and modified 7a cams
Supertech valves and fcp springs + titanium retainers
Custom intake manifold made by kenax
Custom flywheel made by kenax
Tilton OT2 clutch
Billet dry sump oilpan and endplate made by kenax
ATI superdamper
PWR 600x300 intercooler
1100cc bosch ev14
Maxxecu engine management
Balanced bottom end
Glyco / kolbenschmidt bearings
Other stuff
Spax rsx coilover kit
Akmotorsport + powerflex bushings
Griffin aluminium radiator, trunk mount
2x 12" hayden fans
Aeroflow fuel tank
Powdercoated about everything
Rs4 driveline
I'll update specs more when i get more parts and so.
So far completed stuff
Engine bottom end
Engine, gearbox and driveline fitment
Rustwork from wheel arches under inner fenders
Radiator fitment
Front bumper/cooler support bracket
Rear suspension overhaul
Hammu is offline   Post Tools
Unread 24-02-17, 07:56 PM   #2
AndyP
England
AndyP's Avatar
What fuel are you going to use? Interested to see you've gone for a high compression ratio.
AndyP is offline   Post Tools
Unread 24-02-17, 08:03 PM   #3
Hammu
Finland
Ethanol fuel for full boost driving, 98octane could be usable for very low boost.
Unread 24-02-17, 08:10 PM   #4
V6quattro
Netherlands
V6quattro's Avatar
Nice Parts you have got there! Do you already know what turbo you gonna use?
V6quattro is offline   Post Tools
Unread 24-02-17, 08:15 PM   #5
Hammu
Finland
I think garrett gtx3582r 2gen.
Unread 24-02-17, 09:21 PM   #6
Thuppu
Finland
Thuppu's Avatar
Nice project! I have been watching this on audifinns. I have something for you...
Audi 80q B4 Sedan 2.2 20vt - Project
BMW 320dT e46 - Daily user
Chrysler 300C Touring - Daily user
Thuppu is offline   Post Tools
Unread 24-02-17, 09:29 PM   #7
AndyP
England
AndyP's Avatar
Thanks, that was I figured. I wish we could get E85 at the pumps in the UK
Unread 25-02-17, 09:20 AM   #8
V6quattro
Netherlands
V6quattro's Avatar
Okay nice! But I don't think you'r 1100cc injectors can handle that on e85.
Unread 25-02-17, 08:14 PM   #9
kymi
Finland
Great to have this project thread here, thank you neighbour!
And happy to see you finally on E85 side.
kymi is offline   Post Tools
Unread 25-02-17, 09:53 PM   #10
BennyBoo
Be interested in what the rear mount rad setup will be.. Mine is being mounted in a saloon and wondering what inline pump to use...
Scruff4 Lag Monster Noggy.
In Progress:
Volvo K24-7400/7000 hybrids, 2.4 heads, RS4 Rods, Tial W/G's + Screamers, True Dual 2.5" straight pipes :twisted:
BennyBoo is offline   Post Tools
Unread 26-02-17, 06:16 AM   #11
Hammu
Finland
Yeah, it is possible. I have had these for 4 years so i will upgrade when this project is moving.
Everybody turning to alcoholists...
I am going to use davies craig ewp150 with 30mm inner diameter aluminium pipes to radiator and back.
With 30mm lines and pump on 100% duty, theoretical water speed is roughly 3.5m/s if i remember correctly.
Air removal plays huge part in making this rear radiator system being effective.
Yesterday we designed exhaust manifold with my friend, who welds manifolds a lot. Old hks/schwitzer hybrid turbo with broken axle was good mock up for size.
https://www.facebook.com/luisugarage/
Also i welded boost pipes from ic towards throttle body.
Pipes are 2.5" with 3mm wall strenght, just before TB there will be growth to 3" and hpx-e MAF.
Throttle body is fully electric and also 3", same as in c5 v8, b5 rs4 and so on.
Note to self once again. Do not touch welded aluminium. It is hot.
Unread 26-02-17, 01:47 PM   #12
quattro-nick
Belgium
quattro-nick's Avatar
i love your project
audi coupe quattro b2 2.2 20vt project (560hp-600nm)
TWINCHARGED power,zero lag
AEM W/M injection
quattro-nick is offline   Post Tools
Unread 01-03-17, 10:38 AM   #13
Hammu
Finland
Not much of a progress, gathered some parts and welded part of boost pipe and mocked up exhaust manifold.
Unread 01-03-17, 04:14 PM   #14
Wizard-of-OD
Home Country - Syria Current Country - Canada
Wizard-of-OD's Avatar
love this!
Issam N. Abed
iABED Industries
iABED Email | Facebook
The build thread
Wizard-of-OD is offline   Post Tools
Unread 02-03-17, 05:43 PM   #15
Hammu
Finland
