Go Back   S2Forum - The Audi S2 Community > Technical > Brakes & ABS
Unread 15-05-17, 10:01 AM   #1
s2dk
Denmark
Disc brake woble with zimmermann
Hello
Any of you had problems with zimmermann disc ?
Im running 345x32 ml 55 disc in front with 17z kaliber
They brake very Well But If used hard once from fx 180 to 60 km/t they start to Shake alot
Normal deiving there is nothing
Os zimmermann just **** ?
s2dk is offline   Post Tools
Unread 15-05-17, 10:52 AM   #2
4WDrifter
Northern Ireland
4WDrifter's Avatar
As you know new discs and pads need to be bedded in when initially fitted so the we usually preform a series of stops in the car from 70 mph down to zero. A common school boy error is to NOT immediately take your foot off the brake pedal when you come to a halt and start to move again. If you come to a halt and sit for a time with your foot on the brake pedal the hot pads are held tight in contact with that area of the nice new disc and can cause a slight warping of the new disc. So it's just possible that something like this happened so the fault is there from day one.
1996 S2 ABY Coupe silver
2003 S3 8L dolphin grey
2014 RS4 B8 prism silver
4WDrifter is offline   Post Tools
Unread 15-05-17, 10:59 AM   #3
s2dk
Denmark
It Then it should be there all the time not just when you push them from High km/t to low
Its like its get Worse If i brake gently gently and Then hard If that make Any sense
Unread 15-05-17, 11:47 AM   #4
John.
Scotland
John.'s Avatar
4WDrifter
I'd also be questioning if the matting surface on the hub was clean and free from dirt/corrosion before the new disc was fitted?
John. is online now   Post Tools
Unread 15-05-17, 11:56 AM   #5
s2dk
Denmark
Ofc it was
Unread 15-05-17, 12:00 PM   #6
s2coupe3b
Germany
Zimmermann is bad quality, I had only problems after hard driving with cars equipped with them.
s2coupe3b is offline   Post Tools
Unread 15-05-17, 12:03 PM   #7
s2dk
Denmark
what brand to go for ? bremboes?
Unread 15-05-17, 12:16 PM   #8
s2coupe3b
Germany
I think a well know oem brand like Brembo, ATE, Ferodo will be a good value for money and will do the job,
But nonetheless its important to bed in the brakes properly.
Unread 15-05-17, 12:30 PM   #9
s2dk
Denmark
thx Think Im gonna try ate or brembo insteador Maybe some oe Mercedes
Unread 15-05-17, 12:58 PM   #10
RichLV
Latvia
RichLV's Avatar
Strange, I've had no issue with Zimmermann's whatsoever. I've been installing them with Ferodo pads on all of my cars.
RichLV is offline   Post Tools
Unread 15-05-17, 04:21 PM   #11
A1QSHIP
United States
A1QSHIP's Avatar
Same as above. We install them on customer's cars as well with no issue. We also make a point to clean off the surfaces where the hub & rotor meet whenever we have the rotors off.
Look for "shadows" in the shape of the part of the brake pad that contacts the rotor, imprinted on the rotor surfaces. These markings usually indicate that a very hot brake pad has sat against the rotor for an extended time. This could indicate a high spot on the rotor surface that is virtually undetectable. Other than the wheel shaking on hard brake application.
Check your front suspension for play in the joints & bushings to rule that out as well.
HTH, Chris
"Nulla tenaci invia est via"
A1QSHIP is offline   Post Tools
Unread 15-05-17, 04:30 PM   #12
s2dk
Denmark
Its funny had Them off today cleaned all the coating off Them Allso
Noticed that the inside og the rotor was alot smaller than the out side. Its like the rotor is same wide on the outside pas surface than on the inside ? Odd?
Unread 16-05-17, 07:14 AM   #13
veneto rs2
Veneto
veneto rs2's Avatar
i've been using zimmermanns several times and i found they're very good for the price tag.
I had once the problem stated by s2dk with a set of new discs my mechanic suggested to chick in the bin the pads even if they were new (REMSA) and put a new set on (Brembo) and the problem simply disappeared.
veneto rs2 is offline   Post Tools
Unread 16-05-17, 07:28 AM   #14
s2dk
Denmark
Im running ferodo pads
Im just wondering Why are the disc thinner on one side than the other
Unread 16-05-17, 08:08 AM   #15
RichLV
Latvia
RichLV's Avatar
How old are the rotors? Is your caliper working as it should? Both sides are braking evenly? Have you bled both parts of the caliper?
