Go Back   S2Forum - The Audi S2 Community > Technical > Brakes & ABS
Unread 16-05-17, 07:36 PM   #1
John.
Scotland
John.'s Avatar
Hyraulic servo bleeding/priming.
I've replaced the hydraulic servo with a (supposedly good) used one, after topping up the reservoir with some green fluid I started the engine and worked the steering from lock to lock.....all good with the PAS.
But the brake warning symbol shows if I pump the brake. Do I need to bleed fluid from both pipes going to the servo......is this done in a similar way to bleeding the brakes, do I have someone press the pedal while pipe's are loosened??
.....anyone?
Thanks in advance.
John. is online now   Post Tools
Unread 17-05-17, 06:40 AM   #2
Mikes2
Scotland
When I last replaced a hydraulic servo, it took about 50-60 pumps of the pedal to get the light off with the engine running.
This was on a quattro turbo but should be similar.
Mike
http://www.s2-audi.co.uk
Mikes2 is offline   Post Tools
Unread 17-05-17, 07:10 AM   #3
John.
Scotland
John.'s Avatar
Ok thanks Mike.
Unread 17-05-17, 09:13 AM   #4
Bowie69
England
Also check brake fluid level is OK, as a pump can be enough to trigger the switch if the fluid level is marginal, same for the PAS reservoir.
In other words, don't just assume it is the servo switch
Bowie69 is online now   Post Tools
Unread 17-05-17, 09:49 AM   #5
John.
Scotland
John.'s Avatar
ok thanks.
So the brass thing is a switch?!
Unread 17-05-17, 12:18 PM   #6
Mikes2
Scotland
Did you swap the switch over from your old one ?
Mike
Unread 17-05-17, 12:27 PM   #7
John.
Scotland
John.'s Avatar
No I didn't........think I will now!
Unread 17-05-17, 03:35 PM   #8
Dynasty
Norway
Try to disconnect the pressure switch and see if the alarm disappears...
Dynasty is offline   Post Tools
Unread 17-05-17, 07:38 PM   #9
Error404
Moderator
Error404's Avatar
