Go Back   S2Forum - The Audi S2 Community > Technical > Suspension & Steering
Unread 18-05-17, 02:49 PM   #1
hunker7
hunker7's Avatar
Help with checking out part numbers
Hi lads. Received bunch of rear suspension parts and started checking part numbers and they don't match (subframe and diff) what's on 7zap.com.
Anyone can confirm that these will fit my 93' UrS4?
First picture is for differential and 2 others for subframe.
'93 Audi UrS4 Avant LPG
hunker7 is offline   Post Tools
Unread 18-05-17, 03:08 PM   #2
UrS4boy
Canada
You are looking at casting numbers which have very little to do with the part number of the assembly which includes many parts only one of which is the casting.
UrS4boy is offline   Post Tools
Unread 18-05-17, 03:17 PM   #3
hunker7
hunker7's Avatar
Those are the only part numbers I can see on them. Where are diff code/PN located?
Unread 18-05-17, 03:26 PM   #4
UrS4boy
Canada
On the two V8 torsens that I have in my garage there is a painted stamp on the diff housing.
Unread 18-05-17, 06:18 PM   #5
hunker7
hunker7's Avatar
Checked all over it no stamps of any sort. It definitely looks like the correct one visually.
Unread 18-05-17, 09:41 PM   #6
UrS4boy
Canada
Make sure that it is a 4.11 to 1 rear diff by counting the number of times the input flange turns when you turn one of the out put flanges.
Does it have the diff locker mechanism?
Unread 19-05-17, 08:10 AM   #7
hunker7
hunker7's Avatar
If I turn one of the output shafts 2 times input shaft turns 1 time.
It is a locking diff yeah, comes with the little vacuum actuator.
EDIT: when I lock the diff it is about 4 turns on input shaft for 1 turn on output shaft.
Unread 19-05-17, 06:55 PM   #8
diesel des
3.89 or 4.11? Need to be accurate
Sent from my LG-H955 using Tapatalk
diesel des is offline   Post Tools
Unread 19-05-17, 07:00 PM   #9
hunker7
hunker7's Avatar
I'll mark it up again tomorrow and do it again but I'm pretty sure it was 4.11. What car did 3.89 diff come on?
Unread 19-05-17, 07:03 PM   #10
diesel des
Lots of audi ran the 3.89. Maybe turn it 10 times and count the other shaft does 41.1 or 38.9 times.
Unread 19-05-17, 07:06 PM   #11
hunker7
hunker7's Avatar
That's a good idea actually I'll spin it 10 times. What happens if I use 3.89 instead of 4.11?
Unread 19-05-17, 10:32 PM   #12
UrS4boy
Canada
Unread 19-05-17, 11:08 PM   #13
ThatGUY
United States
ThatGUY's Avatar
lol - well said
//-\\ ((_)) //)) //
ThatGUY is offline   Post Tools
Unread 20-05-17, 08:52 AM   #14
diesel des
Your center diff won't be happy and will be damaged over some miles.
Unread 20-05-17, 10:10 AM   #15
hunker7
hunker7's Avatar
I checked again and after 4 turns I have to turn input shaft a bit more to align marks on the output shaft so it is a 4.11:1
