I have another car to finish off for some one else with lots of nice parts and toys on. Building it for Club/Pro Time attack spec.
Out line of spec
Engine
GTX35R
Custom pistions
KKD manifold
Antique wagner inlet ( first edition )
Tial 50mm gate
Tial BOV
Adjustable pulleys
Machined breathers
Wiggings style fittings with aluminum pipe work
Solid lifters
Triple plate clutch
Griddle plate
1.8T coils
Error 404 Raychem harness
Custom engine harness
Tatech pro ecu
4" down pipe
Rear mounted rad
dual 044 pumps
Walbro 450 lift in tank
1000cc injectors
Billet fuel rail
Turbo smart FPR
Suspension / Geo
Audi motorsport dampers 2 way adjustable light weight aluminum casings
Tubular front wish bones with rose joints
Rear end powerflex bushed with rose joint linkages
DMD hub to damper billet brackets
Front strut towers corrected
Lower king pin extended to correct wish bones
DMD motorsport steering bracket with rose joints
MR2 rear mounted PAS pump
Brakes
Front 8 piston RS6 DMD carriers
Padgid RS14 pads
Rear 4 piston porsche with extra hand brake calipers
Exhaust
4" down pipe
4" oval along centre section
4" round over shafts to rear box
3x simonds silencers
All V bands
Saftey
5 point harness's
multi point cage with suspension tied in
life line fire
fire wall
roll over valves
Rear rad with Craig Davies water pump
Fan Cowl and inlet housings from rear window
Cleaned rack with DMD bracket
Home made fuel manifold -8AN
Out line of spec
Engine
GTX35R
Custom pistions
KKD manifold
Tial 50mm gate
Tial BOV
Adjustable pulleys
Machined breathers
Solid lifters
Triple plate clutch
Griddle plate
1.8T coils
Tatech pro ecu
4" down pipe
Rear mounted rad
dual 044 pumps
1000cc injectors
Billet fuel rail
Turbo smart FPR
Suspension / Geo
Brakes
Padgid RS14 pads
Exhaust
4" down pipe
All V bands
Saftey
5 point harness's
life line fire
fire wall
roll over valves
