Gearbox Oil Change-Is It Necessary???
  • Gearbox Oil Change-Is It Necessary???
    Its a C6 3.0Tdi QA 2010, with various codes referring to the 'box and I'm not sure which one is the relevant one....
    CDYA (Engine???) HNL KJC 4F5 0YL N1V/QE
    I've been advised that certain 'boxes require an oil change at 38k miles.
    Can anyone advise whether or not mine falls into this category??
    Many Thanks
    if you are NOT shure, when the oil are changed; change it.....!! use the org oil type as required...not "superduperheavyxxxx type"
      I'm with you in principle, But I understand that certain 'boxes are 'Sealed For Life' , and I don't know if mine falls into this criteria (And would rather trust the Boffins on here for advise than my local Dealer)
        sealed for life in my experience has meant 100k miles...
        is it manual or an auto/DSG?
          It's an Auto, but Multitronic or Tiptronic- what's the difference??
          I'm hoping someone here can read the codes
            Tiptronic I guess? AFAIK multitronic on FWD cars and tiptronic on quattro's. The later should be the better one.
              I have the handbook, and it lists both 'boxes , but doesn't give any info on how to tell which one is fitted.
              I think you're correct (Tiptronic) but I'm hoping someone can tell me for sure from the codes- and then tell me if the oil can be changed, or if there are specific intervals.
              It has the paddles on the wheel, if that helps.
                On your white sticker what is the gearbox code? Ill have a look on Elsa-win and see what it says.
                  Never does any harm to have fresh oil in there
                    Some of the 7 speed autos cannot be refilled though. I have heard stories of garages draining them then realising it cannot be refilled. Im not certain on this though.
                      Can't be filled? That would be seriously weird. I 'know' they must be filled with the oil at a given temperature while using VAG COM at the same time IIRC
                        Thats the DSG that has to be filled at a certain temp and all gears selected before setting the level. They are a doddle with the correct tool. The later 7 speeds are different though so I have heard, I may well be very wrong.
                          I think the 'box codes are HNL KJC OYL
                          Do any of these make sense??
                            Ill take a look mate.
                              Cheers Bud
