During my recent clutch replacement I've had loads of others bits done at the same time. One of which was an overhaul of the propshaft.
As you can see in the pic below the centre bearing mount was a little bit worn
The bearing had torn completely away from the mount and was floating freely along the propshaft. This was something that happened during the accident long before I bought it (as was the sheared OS engine mounting bracket)
Now obviously i didn't really want to buy a new propshaft, sorry should read wait for one to come from germany, so I decided to try using the centre bearing listed in the propshaft thread started by alg.
I can confirm that both the centre bearing (Febi/Bilstein Part Nº 05196) and the CV joints (Löbro (OEM) CV-joint Part Nº 301142/Porsche Part Nº 923 332 032 00) are a straight swap. I don't have any pictures unfortunately as it was done whilst I was at work.
The centre bearing may need the holes elongating slightly to allow proper alignment but it is only by a couple of millimetres maximum.
As for prices I got mine at cost through my mechanic but I think the centre bearing should of been around £20 and the CV joints around £90 each. I'm sure there are cheaper places to get them from such as GSF or Euro.
I haven't had a chance to go out for a long test drive but it certainly feels a lot tighter and the clunk I used to get when taking up drive seems to have gone.
Ben
Ben
