Audi rs3 5 cylinder head 20v be used on s2
  • Audi rs3 5 cylinder head 20v be used on s2
    Can the Audi rs3 5 cylinder head be used on a 3B block?/ is it the same as a 3B /7a /Abu head also can it be machined to fit ??
    In a word, no.
      Why not?
        Its not even close the only thing it shares is the number of cylinders
        Chef
          Search for a picture of the cylinder head gasket and it will all become clear.
            Just put the whole thing in!
            1995 1PissedOff90sigpic1991 USDM CQ 7aT
              Aye old = belt driven new = chain driven with vvt.
              UrS6 Stroker + HTA3586 =
                Full engine swap possible?
                  Sure
                    Isn't that the engine Iroz Motorsport were using, essentially?
                    Not an advocation for them, try a search if considering, suffice to say VERY lots of money
                      07k engine, neu 5-cylinder engine is indeed what Iroz is using. I thought it was Issam that said that the 07k cylinder head stock will flow more air than a modified 20valve head. 2.5 liters to start with and a better flowing cylinder head, your expenses will be for the parts to make it a longitudinal motor from its original lateral mounting.
                      Saying that, I will be staying with the original 20valve for the foreseeable future.
                      "Nulla tenaci invia est via"
                        http://theprojectpad.com/viewtopic.php?t=244
                          above certain horse power (like 500) it will cos the same.
