Audi Coupe Quattro 2.7T
  • Audi Coupe Quattro 2.7T
    Hello!
    My name is Nolbelt Fi z il.
    I am living in Hungary, Budapest, working for SRS Motorsport and VEMS and i am studying to be an electrical engineer. This is enough from me
    I bought an Audi Coupe Quattro for a daily drive car. It doesn't have an engine and gearbox. Tha car is being built yet.
    Some information from the car and my plan :
    - 2.7T (ARE)30V engine
    - 980ccm Siemens deka injectors,
    - 044 Bosch fuel pump, laters i need a Walbro ethanol pump.
    - 2pcs T25, Mitshubishi TD04HL-15T turbocharger. It's enough up to 280-300HP*2 ;-) (edited)
    - Custom made exhaust manifold.
    - VEMS ECU:
    Dual WBO
    Dual EGT
    Electronic throttle controll
    Flex fuel sensor for Ethanol. It can controll simultaneously the Ignition advance,Fuel amount, boost pressure. With this I don't need a programm switch (E85/gasoline) and i can mixing the ethanol with gasoline anytime.
    - Clutch pedal switch for Launch controll and (when the car moving) Flat-shift controll.
    - Custom made engine harness whith a quick connector on the firewall, and relay-fuse panel.
    - RS4 clutch with sinter plate. It's enough about 700Nm.
    - UrS4 6speed gearbox, CBL code.
    - 4 piston Brembo brake from Alfa 166.
    - 5 bolt wheel hub from V8/Urs4
    The pictures and information will be refreshed continously
    http://www.srsmotorsport.com
    Looks like interesing project but why are you aiming for only 280-300 HP?? Isn´t that too much work (engine swap, wiring, turbos etc.) for this power level?
      A piece knows 300 :-) There are 2pcs :-)
      This turbo a little bit bigger than a K04.
        O I see what you mean now
          Janopot! (That's all my Hungarian) Looks a great project. I like the Cavalier also!
            I like !
            02 A3 1.9tdi 130 sport quattro
              Welcome aboard!
              Norbert is a very nice and helpful guy , i wish you luck with your project.
              simon20vq: its "Jo Napot" two words but the Hungarian language is very hard and unique
                Great project! We will need lots more pictures
                  Subscribed!
                  If Norbitron's car builds are like his harnesses, this is going to be solid for sure.
                  Find me on Instagram @pry4sno
                  2010 Golf Sportwagen TDI /// #farmenwagen
                  2002 Dodge Ram 2500 24v Cummins 4x4
                  1992 80q 20v /// Eventual AAN'd Winter Sled
                  1990 Cq /// Project: Because Racecar
                    Very interesting.nice project!
                      Yesterday i bought the second TD04 turbo. The first is still in my 80 1.8T.
                      A little compare with the stock 2.7T turbos. from left to right: TD04-15, RS4 K04, S4 K03.
                      The K04 inducer 40mm, TD04-15 42mm.
                      At this week we will make the engine mount. And if i get the exhaust and turbo flanges we start to make the manifold.
