Have some thoughts on my mind to improve te power on low rev's
But need some help from people who has done things like this before.
If i want to make a stroker engine, is it possible to use a 016 gearbox.
Does the crankcase have a hole of the bearing from the 016 gearbox.
Did read that pisobiker has a AAL crankcase, but will fit??
What else can i do for make this enigine more powerfull a low rpm's
ADU is stock only has it a MTM chip and a 200 20V flywheel.
Also is there a AAN intake manifold on the engine and a bigger IC than a RS2.
Things i can do???
Strokker??
Alu flywheel??
Ballbearing turbo ??
If somebody has some good advise's then please post them
Things i can do???
Strokker??
Alu flywheel??
