RS2 studs are different to the S2 studs aparrently. I overlooked that, and Audi only have 9 in stock (of the required 16). At the moment I don't even have an ETA, so trying to figure out an alternate. More delays...
Ah thought you knew
RS2 Parts list from my forum archive:
Part number Description GBP QTY Total GBP Notes
N 906 486 01 Ex manifold studs £0.53 16 £8.48
034 253 031A Manifold £421.52 1 £421.52
034 129 589A Ex manifold to head gasket £31.33 1 £31.33
046 145 749 Turbo to manifold nut £0.73 4 £2.92
N 902 002 01 Ex man. To head nuts £0.64 16 £10.24
N 902 002 01 Wastegate to manifold nuts £0.59 4 £2.36
035 129 589D Turbo to manifold gasket £9.10 1 £9.10
035 145 773D Top oil pipe gasket £0.66 1 £0.66
035 145 757D Lower oil pipe gasket £0.74 1 £0.74
N 013 8128 Lower water pipe seal £0.08 1 £0.08
N 013 8149 Upper water pipe seal £0.05 1 £0.05
857 253 115 Flexi pipe gaskets £7.94 2 £15.88
N 902 002 01 Wastegate to flexi nut £0.64 3 £1.92
N 900 850 01 Flexi to D/P nuts £0.14 3 £0.42
N 010 24416 Flexi to D/P bolts £0.23 3 £0.69
447 253 115 Turbo to D/P gasket £3.76 1 £3.76
N 903 690 01 Turbo to D/P nuts £1.03 3 £3.09
N 900 730 01 Lower turbo to D/P nut £1.37 1 £1.37
You can cut down the S2 studs although it's not ideal, it's a listed mod on the forum by Doug_RS2 somewhere........
