Sorry if this thread stomps over some well trodden territory, but seeing as I finally got some time to compare an S2 turbo and RS2 turbo side by side on the bench last weekend its only right and proper that I share this.
Apologies if this isn't news to everyone - but hey ...
The S2 and RS2 hot side housing is the same as far as I can tell - only exception being of course that the RS2 hotside is machined to accept the larger turbine wheel of the RS2. This surprised me as I always thought the RS2 hotside housing was physically larger than S2.
The centre section looks identical as well (which I did expect) - but I seem to recall reading somewhere that the RS2 application uses a thicker shaft (connecting the wheels) and therefore a different bearing. Dunno about that yet but its believable.
The cold-side (compressor) is of course where the differences are rather obvious. The RS2 housing is visibly bigger than S2 and of course the compressor wheel is different.
'So what' I hear you say -
Well what I think this means is that you could take the healthy hot-side housing from an S2 turbo and have it machined to the dimensions needed for the RS2 application. Pretty handy for me sitting with an RS2 turbo that has an alleged crack in the hot-side housing, and I have a spare S2 turbo to play with... Maybe sourcing a hotside will be easy after all
Talking of cracks - anybody know of a UK specialist that can perform reliable crack testing on something like a turbo housing ?
There is a lot of casting flash on the internals of these hot-sides - I'd like to get the turbos stripped and crack tested before polishing up the internals as best I can - just on the hotsides.
Photos and dimensional info to come in due course....
Paul
Paul
