How does the air bag trim come off-RS2
  • How does the air bag trim come off-RS2
    Hi Fellas,
    Anyone removed the cover over the air bag on the passenger side?
    Mine has got the s.h.i.t.e wood bollarx stairing at me, I hate it!!
    I have changed the door trims, looks lurvly is carbon
    I have bought some carbon fibre to cover the wood bit. if it comes off, then I can sort it. If not its getting painted black in sittue!! or may be Noggy....hmmm.
    cheers
    Rob
    Rob..
    94 RS2 Noggy,LHD,MTM map,18"cup 1s,245/35/18,Bilsteins,RS2 H&Rs,Cup splitter.
    87 UR 20v ABY
    97 S6 Avant
    96 A6 C4 2.5 TDI quattro avant,Ming,Wietec/eibach,chipped
    1967 Ford Mustang,Eleanor,460ci v8
    Originally posted by GT500
    Hi Fellas,
    cheers
    Rob
    forget it to change the trim, it isnt possible, a friend of mine made it, but it was a fu**** work. I hope you want a working airbag for your passenger.
    carbon has everbody, paint the wood! mine is painted in oem rs2 blue (nagaro blue):
    Christian
    Audi rs2cabrio (in work) :mischeif: and alot other stuff
    My Audi Cabriolet
      Thanks Christian,
      Its not just me then! Wood is bluudy awfull!
      Nogaro looks sweet!
      Rob
      Rob..
      87 UR 20v ABY
      97 S6 Avant
        mmm nogaro trim pannels
          hey rs2cabrio, did you removed the trim from your car when it was painted? if yes, how can it be removed?
          Audi Quattro WR
            Hello,
            what about your car skull?? was a long time off line.
            no, I havent removed the trim, I gave the complete airbag to the painter.
            here is a video how you change the trim, but it should be no people working on the airbag without a certificate!! I have one of Audi (I work there )
            http://www.meckisfaq.de/viewtopic.php?t=260
            Christian
            My Audi Cabriolet
              How??
              Have seen the video but in this case there are no airbag inside. When you pull out the airbag box completely how do you then take out the bag? Is it easy or can something be damaged if you dont have the right tool or something.
              Really need to know this. Sick and tired of driving around in a boat.. toot toot
              Audi RS4+Long sportquattro
              www.hansenmotorsport.no
                Anyone??
                  If you remove the passengerside glovecomparment
                  above that you will see the Airbag in its full glory and you easy sort out
                  how to thake that out
                  Beware : always disconnect the BATTERY
                  and when you change or disconnect the airbag ,the Airbag light on
                  your dash will stay on and must be reset by the dealer.
                  RS for ‘Rennsport’ - ‘Motorsport’ in German
                    Ok thank you. I will try to do so in the weekend.
                    I really hope it will come off easy otherwise the VOLVO OCEAN RACE will have a new competitor. The AUDI R(s)A 2 from the Kontiki expedition..toot toot
                      I there!
                      me and a couple of RS2 owners/friends bought a damaged (back) RS2......
                      we put the car down to bits for spare parts (yes yes i know we are cannibals!)
                      and trow away the chassis.....
                      about the trim in the passenger airbag..............
                      i must tell you (like others told you already) that really you DON'T want to take that thing out!
                      the trim it's locked from behind............that means you have to take out the bag......
                      and put everything back in position............
                      well i wonder when on ebay they sell the complete set of trims in carbon for the RS2
                      will they give you the step by step instructions for fitting?
                      we discover this because for a bit of fun.......at the end of the job we set/blow off that particular airbag (i wanted to know badly how the trim was fixed! i dreamed about that carbon when i had my S2 3b).........nice BANG must said..............
                      if you ask..........yes the trim was damaged during the process
                      but we discovered that it's real carbon fiber no fake pretending material
                      Ciao Stefano
                      P.S.
                      the airbag warning light will go on if you take off any airbags connection with the key switched ON and it will stay on til a VAG setting.....
                      but no problem if you loose a connection if the key is OFF for the whole time and switched on after the connection will be put back in position
                      easy to assume that disconnecting the battery is the best solution all over
                      http://www.audisportclub.com/
                      http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
                        Thanks. Now i have carbon. My tuner fixed it for me and it took about 10 minutes
                        Looks great and now im driving a car without bits of the forest inside..
                          i know this is an old topic but this might be useful for someone.
                          changing the trim is possible and not that hard. i have made some photo when i changed mine,
                          First drill out the rivets
                          then use some pliers to undo the 4 nuts on the sides
                          bent these clips up
                          now use a screwdriver to undo the 4 hooks on top and the 4 on the bottom
                          take the airbag out
                          undo the bolts that hold the trimpiece
                          put the new trimepiece on and put everthing back together
                          5 Cylinder Freak
                            Nice writeup - thanks!
                            Still wood in my boat..
                            Cheers, Torben
                            '94 B4 Avant S2
