Westfalia Removable Towball
  • Westfalia Removable Towball
    Towball to fit the OE towbar I got from Sienna, I'm using the one from a 200 Avant which sits a bit low, so a longer one would be cool.
    bttt
      If you can source there please let me know (PM would be great) as my friend is after one too. When he bought his car the towball wasn't there
        If I find 2 you will be the first to know! I used the 200 ball for now which kind of works.. I just towed the bike 250miles today, I'm now on holiday in Cornwall. I got some height back on the front of the trailer by unbolting the hitch and bolting it back on below the trailer spine.. seems ok, was pretty stable at 90mph..
          Here's a pic of the 200 towball.
            Can you get them from www.towsure.co.uk
              Is that 200 ball cast or something else? That could be modified reliably (though illegally) if it's not cast item.
                Towsure put me on to Towequipe.
                http://www.towequipe.co.uk/
                http://stores.channeladvisor.com/tow...l?sck=64575886
                Currently reduced from 199 GBP to 150GBP
                  Aaarrgg!! thought it was too good to be true, they just told me they Westfalia haven't got one after all..
                    After asking Towsure to give Westfalia a gee up, they apparently came back and said they've managed to source one from an OEM supplier.. So I'm now hoping I am going to get one after all. Fingers crossed, I'll let you know.
                      Thats good news, hope its sorted soon
                        Arrived today! Here's a pic of both balls for comparison
                        There's about 6 inches difference in height between the two.
                          Lucky boy!
                          I have the one you just got .. coupe one? fitted to my RS2, any chance of trying your 200 one? mine sits a bit high.. I have to have the car on the trailor sat way back so there's not too much "ball" weight.........
                          I would pay the postage...
                          Rob..
                          94 RS2 Noggy,LHD,MTM map,18"cup 1s,245/35/18,Bilsteins,RS2 H&Rs,Cup splitter.
                          87 UR 20v ABY
                          97 S6 Avant
                          96 A6 C4 2.5 TDI quattro avant,Ming,Wietec/eibach,chipped
                          1967 Ford Mustang,Eleanor,460ci v8
                            Originally posted by GT500
                            Lucky boy!
                            Firstly the 200 ball doesn't belong to me so I would have to ask about that, second, lowering the ball will make your problem worse, transferring more weight to the ball not less, anyway, if you still want to level the trailer, maybe you can unbolt the hitch and space it upwards with longer bolts. I did the reverse of this with the 200 ball, I bolted the hitch to the underneath of the trailer spine, not ideal as you cant really get your hand through the release handle.
