Hi,
I already asked a few questions (http://www.s2forum.com/forum/showthread.php?t=23338) about what changes are needed to get my ABY into ADU specs and run standard RS2 software (later on MTM RS2 software).
I know the R201 resistor in the ECU needs to be changed into a 5k6 Ohm one to handle the fuel mixture with the RS2 injectors with the 3 bar MAP sensor.
I also want to fit the ADU cams, but read on a few forums the cam markings are not equal to the ABY ones and the cam wheel needs to be shifted 1 tooth to the left. See also attached picture.
Is this thrue while I leave my ABY waterpump in place, or should I stick to the markings on the ADU cams?
