My plan is to use the standard pistons with a reduced CR and keep the squish so i save money not buying new pistons and in the long run i save on fuel consumption.
I got my 50cc burette through the post the other day and i cut up some old polycarbonate i used for the windows and got too it.
I worked out all of my combustion chambers to be 44.7cc`s (+/-0.1cc).
The steel head gasget is 8.18cc`s.
The piston dish works out to 3.75cc`s with a minor innacuracy because the sqush area on standard KS pistons actuall protrudes the block deck height and cannot be calculated using a burette. If the pistons were deck height i could have used a burette.
And cylinder volume 445cc`s
Add these all together and divide them by the top three and it works out to,
8.86:1 commpression ratio
This is much lower than i belived it would be and i have a suspicion tht the head has been skimmed so the figure would have been lower. I calculated that if the dish was taken out to 70mm instead of 60 and it was taken from 1.2mm deep to 1.7mm only loosing .5mm on the crown thickness. This will bring the piston dish to 6.78cc`s and a new CR of 8.46:1.
So i`ve took the pistons to a local engineering firm and hes going to machine out the pocket with a radius`d cutter on a cnc mill, all for £35 so well within my budget, i`ll post pics when i get them
