hello just wondered, i bought this catch tank from 034M. Has anyone used this, mounted this?? it looks like a good kinda bit, hope some one can give me a hint??
catch tank
Assuming its a cyclone type with a drain at the bottom and two inputs at the top...
Input one to crankcase vent via the PCV valve.
Input two to the vent pipe on the head.
Drain connects back to sump - must be under the oil level of course ! Or just dump it when full of oil, but I don't see a window on the tank for that.
That top filter is just an air vent - it might stink of fumes depending on where you put it... EIther route to a location like inner wing if its smelly or just have the MAF pipe inhale it, as long as you are happy most of the oil is being extracted by cyclone nature of catch tank.Paul Nugent
thank
you, there is no drain in the bottom.japanischer industriabfall nein danke!!
www.rackeltrim.se Icelandic Division
