Go Back   S2Forum - The Audi S2 Community > Technical > Brakes & ABS
Unread 10-05-08, 05:18 PM   #1
newsh
newsh's Avatar
Brake warning - G00 2000
Brake warning came up on the way home today, Brake fluid's ok but G00 2000 looks low, trouble is I haven't got any, is there anything else I can use, its says "use only mineral oil" on the reservoir, anything I can buy at Halfrauds? Green ATF? Or do I have to wait till the steeler opens monday morning? I've got some Type G ford ATF in the garage
newsh is online now   Post Tools
Unread 10-05-08, 05:32 PM   #2
bertman
Current Country - United Kingdom
bertman's Avatar
When do you need it john,got a couple of spare litres from the bomb and pas pump change if you want it.
Rob
Ragussa green avant RS2+ spec
Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
Audi coupe gt-slow as hell but loads of character-sold
bertman is offline   Post Tools
Unread 10-05-08, 05:37 PM   #3
Nuvo
Nuvo's Avatar
Maybe you can source one of these alternatives at a local factors?
There is Febi Bilstein 7.1 Mineral Base Audi Power Steering Fluid or
Pentosin 11S Synthetic Mineral Base Audi Power Steering Fluid
I'd personally hold out for the real stuff for peace of mind even though the above alternatives are quoted to safe to mix with existing G00 2000 fluid.
Nuvo is offline   Post Tools
Unread 10-05-08, 05:44 PM   #4
mcandmar
Ireland
mcandmar's Avatar
G002000 only IMO, i've heard ATF is bad for the seals.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
mcandmar is online now   Post Tools
Unread 10-05-08, 07:04 PM   #5
BrianSmith_S2
Home Country - Northern Ireland Current Country - British Antarctic Territory
BrianSmith_S2's Avatar
Get it from the stealer or german and swedish...but i think you will find the part number has changed. (see attached photo)
Do not put atf in it cos it will knacker all your seals
BrianSmith_S2 is offline   Post Tools
Unread 10-05-08, 08:00 PM   #6
Rusty
Moderator
Rusty's Avatar
I just use the Febi stuff from GSF :scrathc:
K24 Racing - K24R Products
Rusty is offline   Post Tools
Unread 10-05-08, 08:35 PM   #7
Error404
Moderator
Error404's Avatar
i've heard the citroen hydraulic mineral oil will be ok too, but don't quote me.
Unread 10-05-08, 09:21 PM   #8
vader s2
Ireland
G 004 ooo m2 is the only one to use. hold out untill you get the right gear
using ATF can and will damage your pas pump i should know i busted two pumps before i wised up and started using G 004 000 m2 ATF will eat the seals in the pas pump. better to be safe then sorry later on.
vader s2 is offline   Post Tools
Unread 10-05-08, 10:15 PM   #9
macspring
I agree with others !
Definitely hold out for the right stuff and buy extra in case it is the case that you have a small leak somewhere and it will happen again.
Better to have too much than none. Also maybe carry a small bit in the car until you decipher why your level has or is going down. HTH.
ATF will wreck the seals.
Kind regards,
Unread 11-05-08, 06:02 AM   #10
quattro20v
Finland
quattro20v's Avatar
That Febi stuff is ok but the ATF is not.
quattro20v is offline   Post Tools
Unread 11-05-08, 01:12 PM   #11
newsh
newsh's Avatar
Cool chaps, I will wait for the Good Oil (as they say in Australia)
Need to have a good look for the leak, hopefully just an O ring..
