Old 07-06-08, 09:05 PM   #1
magarv
Home Country - Norway
magarv's Avatar
Project: S2 Coupe Continously upgrade
Here comes a little project thread about my 1991 S2 coupe.
I bought the car spring 2004 as a stock “un-touched” car. This is a long term project and I keep updating it as times go by.
These are the modifications I have done so far
Suspension and brakes:
H&R coilovers with custom springrate.
Sellholm topmounts.
Aluminium bushings in subframes.
Powerflex bushings front and rear wishbones, rear diff and FARB
034 Motorsport engine and gear mounts.
Whiteline adjustable RARB
Front brakes: 345mm disc from Mercedes AMG with 4 piston Wilwood caliper.
Rear brakes: 312mm disc from Audi A4 with 4 piston Wilwood caliper.
Engine:
Remap by Jonus racing / Tor Øyvind Skinne.
7A cams.
Pure Performance Factory exhaust manifold
Turbonetics T04E Super60/P-trim.
MSD Digital 6+
MSD HVC Blaster II Coil
Stiffer WG spring
Bigger IC (530x300x76).
25 rows Earls oil cooler
Reverse inlet manifold
Siemens deka fuel injectors 630cc@3bar.
Aeromotive FPR.
Walbro 255LH intank fuelpump.
Bosch 984 fuelpump inline.
3,5” stainless exhaust system with one Magnaflow silencer and one Ferrita silencer.
Drivetrain:
01E CGR 6 speed tranny
Interior:
Removed backseats and carpets.
Wieschers-sport roll cage.
Sabelt GT3 seats with 4 point belts.
Exterior:
18" Zito Titan rims, RS2 frontbumper and headlights.
"Ring addicted"
8,43 BTG with trafic and roadworks:http://www.youtube.com/watch?v=pYg50Bg2lVQ
magarv is offline   Post Tools
Old 07-06-08, 09:13 PM   #2
Acidburn
Acidburn's Avatar
Looking good and the wheels suit the car.
Do you have any side on shots or front/side shots and any shots of your rollcage?
Audi s2 coupe, 20v Ur quattro, Vw Passat
Acidburn is online now   Post Tools
Old 07-06-08, 09:16 PM   #3
Rusty
Moderator
Home Country - United Kingdom
Rusty's Avatar
Cheers for the writeup, seems like a beast! Explains why the 'ring laps you'd posted yesterday were a littel faster than a standard car! I'd say that my coupe is capable of a 9m BTG on a clear track.
Looks mean on those wheels and nice and low, are you running road or track tyres?
How do you find the H&R coilovers? What spring rates did you go for?
What sort of power & torque is it running on the T04 setup? Is it laggy at all?
Please can you post some shots of the interior too Interested in the cage
AndyC
K24 Racing - custom design, bespoke parts
K24R Threads
Require custom designed parts? Please contact me andy@k24racing.co.uk
Rusty is offline   Post Tools
Old 08-06-08, 07:57 AM   #4
Bram
Netherlands
Bram's Avatar
Any performace figures from that engine? Looking good btw!
CT355-0.63A/R, OEM cylinderhead, ADU cams PROMO-Racing clocked, Full Wagner kit, Full 3" exhaust, Joe sinter sport clutch with 7A lightened FW, S8 mk1 rims, 360mm RS4 brake discs, Porsche GT3 mk1 calipers, Full grey RS2 interior, VEMS,...
Bram is offline   Post Tools
Old 08-06-08, 08:49 AM   #5
anton
anton's Avatar
wow, nice bit of kit!!! awesome ring lap vid too you should go with the forum in october! as everyone else says...more piks please!!!!
Ant
91' Coupe quattro 20v - project
KW V2s, stainless de-cat, QRS top mounts, 034 injectors, elec rear windows
now scrapped and selling off remaining parts
03' BMW 330CI - daily
The Dark Side....
anton is offline   Post Tools
Old 08-06-08, 11:43 AM   #6
magarv
magarv's Avatar
Thanks I think they look good, and they are light as well. (19,6kg 18" x 8", with 225/40-18 Toyo R888)
You can get the roll cage with different options. From a simpel rollbar to full rollcage.
mine is with these options:
- Roll Cage in St 52 steel and 45 x 2,5 main bars with paint
- Lateral protection
- H-strut
- Cross instead of diagonal strut
- In addition I have welded in a pipe in the main bar for the seat belts.
It was 4 weeks delivery time when I ordered mine. (Remember to inform if you have sun roof and back seats or not.
http://www.wiechers-sport.de/ueberroll/preise.html
"Ring addicted"
Old 08-06-08, 12:18 PM   #7
magarv
magarv's Avatar
It is not exactly standard anymore...
As I mentioned in the last post I run Toyo R888 tires. I bougth the coilovers through a friend that have some some good contacts. I dont remember the actual spring rates, but I can provide spring part no (and full kit no) I think they are based on the standard H&R kit for S2 Coupe, but with aproximatly 40% stiffer springs.
I am quite satisfied with the T04 setup, and I dont think it is too laggy. I am currently using a small exhaust housing (0,50 a/r) and togheter with the 6 speed tranny it works well. But the turbo is not the ideal turbo for my setup, I bougth it because I have an upgrade in the back of my head
The compressor side is capable of 550+ hp and I am now in the 400+ somewhere. (stock bottom end)
I also think that the 'netics turbos are very robust and can handle a lot of beating. In the video in my signature a had a big boost leakage and still the turbo survived several laps around the ring.
G-tech measurment done with my old 01A 5 speed tranny and 1,5 bar boost in 3. gear
I think 350 Wheel hp is on the limit, or a bit over, what the stock bottom end can handle
Here is the hose that I discovered right after the 8.43 lap
"Ring addicted"
Old 08-06-08, 12:38 PM   #8
Rusty
Moderator
Rusty's Avatar
Be careful with the bottom end on a 3B with 400bhp
That's a nice little leak you got yourself!
AndyC
K24R Threads
Old 08-06-08, 12:43 PM   #9
anton
anton's Avatar
8.43 with a boost leak
that link to roll cage place is good too cheers, i will be fitting a cage in time. like the wheels too, have a pik of a red car in the states with a set of them, was thinking about getting a set, bit too commen now with two ppl who have them
any chance of a pik at the engine bay and from the boot, interested in some more cage shots, looks like a really nice kit
Ant
The Dark Side....
Old 08-06-08, 12:59 PM   #10
Rusty
Moderator
Rusty's Avatar
The website gives lots of options to think about. I think I'd go for a half cage (roll bar) so that I wasn't worried about headbutting a cage all the time (sunroof makes things rather tight anyway) but who knows. Full cage requires some proper seats to be fitted over and above the Recaro Speed...
AndyC
K24R Threads
Old 08-06-08, 03:39 PM   #11
Acidburn
Acidburn's Avatar
cheers for the pictures/specs/stories above, look forward to seeing engine/boot shots
Old 08-06-08, 07:34 PM   #12
4WheelDrifter
Home Country - Devon
4WheelDrifter's Avatar
Thanks for sharing this with us Magarv. What colour is your car? It looks good.
Hopefully we'll meet at the Nordschleife sometime. I wouldn't mind a pax lap in that.
Thanks for the pictures of the roll cage too. I'd be interested in seeing a boot shot too. I'm pretty close to putting a cage in mine, but I'm not sure what it would be like to live with every day. I would love to sort out the bendiness of the Coupé chassis though.
SS
4WheelDrifter is offline   Post Tools
Old 08-06-08, 07:53 PM   #13
magarv
magarv's Avatar
I know 400+ hp it is on the limit and past
But I also think that it is ignition failures/missfires that is the biggest cause to "banana" rods... In my opinion you can minimize the risk with a proper map and good ignition system. I have driven 25000km with this setup and the bottom has done 240 000km
I think it holds togheter because of the good map and the MSD ignition system that keeps missfires and "spark hoops" to a minimum. (and in addition correct "narrow" rotor and good ignition wires)
Anyway I am not to worried, I have a few "spareparts" laying around
New block, washed, painted, machined and ready for assembly:
New head, machined and overhauled and some parts for a proper intake manifold:
"Ring addicted"
Old 08-06-08, 07:57 PM   #14
magarv
magarv's Avatar
For those interesed in the wiechers roll cage, here is some good pictures from a realy realy nice swedish coupe: (see page 39, 40 and 41)
http://www.zatzy.com/projekt/284837-...-coupe-39.html
"Ring addicted"
Old 08-06-08, 08:02 PM   #15
magarv
magarv's Avatar
Here comes some pictures of the engine bay. Some new and some old.
"Ring addicted"
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©2003-2009 S2forum.com. All Rights Reserved.
