(steel ) crankshaft sprocket
  • (steel ) crankshaft sprocket
    i'm having some more (steel ) crankshaft sprockets made so if anyone wants one let me know ASAP .
    i've had one on my car for nearly 9 months now without any problems the price is £70 +postage probably won't be ready till january 2009 sometimes .
    Is this for any engine or just aby/adu?
    looks a quality item again jamil
      as far as i know aby adu 3b aan 7a are all the same .can someone confirm this ?
        All the same, this one is better than the other ones I've seen as it has the locating dimple
          what is the difference of this and the OEM unit?
          And also i thought this was changed every time you did the cambelt.So it should last a lot more than 9 months.Is this unit so good so as to keep it longer?(say...2 cambelt changes?
            The difference is that this is made from billet steel and not a moulded unit. Problem with the OEM unit is that they tend to crack.
            Sleeper S2 Avant +450
            A6 Avant 2.7t Stage 3
            Audi S2 Coupe RS2'ed
              No,
              not all the same, you'll have to wait till this evining for me to post some piccies...soz...at work...
              Carlos.
              On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.uk
                Originally posted by Flat on my back View Post
                No,
                i have 7a and aby with me and they look exactly same .
                  I've just seen an ABY pulley and compared it to my 7A, the 'shoulder' on the back of the 7A is longer than the ABY...was thinking it would put the woodruf key on the sprocket in a slightly different position on the nose of the crank.
                  Only got a 7A crank and sprocket/pulley to check.
                  ABY cranks aren't different are they?
                  Can do some checks on my 7A?
                  Carlos.
                    ABY, 3B & AAN are the same I wouldn't be bother about the 7A it doesn't generate enough torque to justify having one.
                      Hmmmm...
                      Feels like i'm being got at... not enough torque...
                      Should all be hunky dory then.
                      Carlos.
                        I checked the FA for part numbers and they are the same for all models AFAIK
                          Yeah but - whilst they are listed NOW as the same part, it may well be that some engines had variations of this in the past - only possible to find out if 'FOMB' has a part number visible on an older variation.
                          Same deal as paper head gaskets on the early engines... and bearing shells... get my drift ?
                            there is no part number on these sprockets but they do look the same
                              i listed it for comparison .7a uses lots of bits which are same as 3b aan aby adu.
