S2 coupe rear brake kit
This is a sticky topic.
  • S2 coupe rear brake kit
    I can supply the full 300mm rear brake up grade kit for £470.32,everything required as listed on the forum
    Quattro Corner Audi OEM Parts
    Is this the version with the machined 280mm discs as docume,ted by s2central ?
    RCN
      These are the parts that people keep asking for-
      B7 Disc, 300x22 vented - 8E0 615 601R (2-off)
      A8/S8 carrier - 4D0 615 425C (2-off)
      Calipers from RR quattro or UrS4/S6 - 447 615 423 and 447 615 424
      S8 pads for those 280mm discs - 1J0 698 451L
      50mm long caliper carrier bolts - N101 815 02 (4-off)... Shortened to ~35mm for the task
      Also recommended along the way is new brake lines and clips for handbrake...
      S2 Coupe rear hose - 893 611 775 (2-off)
      Brake union clip clamps - 4D0 611 715B (2-off)
      Handbrake cable lock clip - N900 527 02 (2-off)
      This is what you get
        Nice work!
        If only I had "Big front" brakes and £500.
        Cheers,
        Steve.
        The Perfectionist
          @Pete - That is an absolutely stonking price on that - phenomenal in fact...
          Only way to make that kit better is to throw in a handful of 1mm thick washers to space the carriers out !!!!!
            Yes, the coupe upgrade.
            S2Forum.com Administrator
              I should be able to get the discs turned to size if required but at a cost hope this helps
                Forgot to ask Pete - what's my commission on these kits ?
                Heheh - I'm kidding - just glad this is easier than ever for anyone to do - and the price is really good !
                  Will there be an Avant version of the kit?
                    See the other thread... Heheh
                    As a B4 Avant you have two main options ---
                    1. The full monty B7 / 8E0 version with 300mm discs, calipers, pads & carriers ==> expensive though
                    2. The other B5 sourced vented conversion - I can't find details, but sure Ben or someone had a good thread on it.
                      Here we go - I think...
                      http://www.s2forum.com/forum/showpos...7&postcount=41
                      Need to confirm with Ben though
                        Gotta say though... Seems a bit weedy with 256mm vented on that path tested a longtime back by Ben (and TT discs - yuck)
                        If those B5-S4 calipers accomodate a 22mm disc, and the handbrake is good on B4 location - then there should be no reason why the A8/S8 carriers for 280mm and those 8E0 discs spun down to that size shouldn't work. Assuming the B5 S4 caliper is same style as RR/UrS4/S2 then the pads specified on the 280/8E0 COupe upgrade should be great too...
                        Capiche ?
                          Nice one Pete
                          Often the problem with most of these upgrades is sourcing all the parts from different places and knowing what go get, so supplying the lot, and offering to turn the discs down as well is an absolute bonus
                          Now wheres my wallet (i wish )
                          Audi A4 1.8Tq
                          VW Passat 1.8T RIP
                            Capiche ?
                            Would one of the brake gurus like to confirm this idea with B5 S4 rear calipers on A8/S8 carriers with the B7 S4 disc reduced to 280mm diameter ?
                            Or maybe some kind guineapig with B4 Avant/Sedan would like to try it out ?
                            It would be much cheaper than the full-blown 300mm setup from B7 S4.
                              Great work Pete!
