Hello.
Have read all the forums, google etc, but before I'm fitting and searching for an catch can, I want to know few questions to be sure I understand all the systems working principles.
1) I've seen that one forum member has fitted catch can with two inlets (or outlets?). First one goes valve covers lower outlet, and second one goes to the big crankcase hole on block. As far I know, flumes makes pressure in crankcase that passes by piston rings on explosion. Question - where does all those flumes go in this case? Picture attached below. Doesnt it make overpressure and slow down engine speed or elsewhat?
2) What meaning is of the big ventilation hole of block (right-side)? It is used for oil return or from there also comes flumes out? Or else what? Currently I understand that from valve cover and the big hole on the block are flume/oil outlets that needs to be joined to catch-can and third join has go either to atmosphere or inlet. Am I right? Or maybe not?
3) After oil and flumes has been seperated, how good it is (and is there a MUST?) to bring flumes back to intake? Does it somehow make difference of clean air, maybe there is hotter inlet air for IC to be processed etc? Or can I just put an air/oil filter on the top of the catch tank and let those flumes go out themself.. or must there be a sucking efect (vacum before turbo as for an example)?
