Hello fellas!
I wanted to inform You about a theft from one of my colleagues. If Somebody can give us a successfull "hint", we will reward 5000euro!
PM me, if somebody finds something suspicious...
FYI we have come to the conclusion tha tit must have been 5cylinder-geeks because they picked some smaller unique RS items out of the shelves between many 4cylinder parts
This RS2 was stolen in the night from Monday 07.09. to Tuesday 08.09. out of my garage in Germany (Braunschweig -near Wolfsburg).
- black leather seats
-322mm Porsche-brake and black Porsche Cup1-rims
-76mm SKN high-grade steel exhaust
At the time the engine was customized with Garrett GT3582 turbocharger, PKM-exhaustmanifold, PKM-crankshaft (original minus 6kg), Pauter-rods und Mahle-pistons with a compression of 8,5. The Downpipe was not made yet.
Sachs-metal clutch disc with 3B-clutch components and Fidanza aluminium flywheel:
Cylinder head was customized by PKM (wided tubes):
PKM-exhaust manifold and significant red-black valve cover with short PKM-manifold (polished on the inside)
Turbocharger GT3582R with intercooler in 280x550x76mm with significant writing „Turbozentrum“ on top and 70mm inlet/outlet
100mm induction pipe with original air flow meter in high-grade steel housing with connection for PopOff-valve.
They also stole an original RS2-intercooler with a welded outlet front left. This is useable for manifolds with throttle front left only, not for original manifold.
Also stolen: a complet set of Porsche Cup1 rims high-gloss polished with polished hub caps
conspicuous spare wheel hollow subwoofer with writing “quattro” and blue light
