I will be getting these on order next week with a 2 week turnaround The kit is only tested on RHD vehicles but if you have a LHD vehicle and wish to try this kit then please get in touch!
Here are the kits:-
ABY S2 / RS2 Starter Kit
The Starter Kit consists of:-
The catch tank has been designed to utilise the ABY/RS2 breather system and fit to the ABY/RS2 strut brace (requires 2 9mm holes). The required mounting hardware is included to mount the tank to to the strut brace.
The tanks are made from welded sheet aluminium and are of a high quality, they are a bare finish and so can either be left or primed and painted, should you decide to colour code to your car or engine bay. I have had a tank from the same manufacturer for 18 months and it still looks very good. They have a capacity of just over 1 litre and have some nice features to make installation into an ABY S2 or RS2 really simple:-
To finish off the installation you will need 35-40cm of 19mm bore hose to connect to the breather system and to either sort some return pipework or a 19mm bore breather filter. The N80 and fuel breather will also need to be sorted.
IMO, this kit is for the more adventurous or experienced mechanic who likes to finish things to their own specification, it enables you to colour code the filter and / or pipework to your car and you get to decide the quality of the parts you fit, e.g. flourolined pink hose and a wire mesh filter .
The basic kit of tank + mounting hardware will be £75 delivered.
ABY S2 / RS2 Standard Kit
The Standard Kit consists of the Starter Kit with the addition of:-
You will still have to sort N80 and fuel breather but the filter completes a vent to atmosphere install.
This kit saves sourcing some of the bits and bobs required to finish the installation and is supplied with the right amount of hose so you don't end up with an odd end lying about. The N80 and fuel breather will still require modification but I'm working on a solution for this (see below).
The Standard Kit is £99 delivered.
For kits pre-ordered before 31/10/09 I will offer a 10% discount The kits should be on their way before the end of November if all goes to plan.
I can also offer braided hose for an extra £10, so £109 delivered. Please let me know if you require this option when ordering.
Coming soon
Many thanks, to order, please email:-
andy@k24racing.co.uk
P.S. N80 is the carbon canister / fuel breather EVAP solenoid.
Here's some pictures of the prototype on my car, the latest tank design has been improved to give more options on the outlet. My tank is shown with return pipework c/o an existing A/C pipe
Here are the kits:-
- Custom designed catch tank.
- Mounting hardware.
- The inlet faces downwards to make connection to the existing breather system easier and neater, it is also the correct diameter!
- The tank is fitted with a bracket that securely attatches the tank to the ABY strut brace.
- The bracket is designed to provide clearance for either a breather filter or 90 degree bend for return pipe work.
- The tank is internally baffled to encourage oil vapour deposition and prevent blow-by.
- The sight glass is easily visible in the ABY engine bay.
- The M10 drain plug is easy to reach and has more than suffient material to allow attatchment of a nipple for a sump return system.
- 0.5m black Aeroquip oil hose to connect to the ABY/ADU breather (oil resistant, unlike silicon hose).
- Cotton breather filter.
- Clips for the hose and filter.
Coming soon
- Retun pipe kit for this tank.
- N80 integration options for inlet return and vent to atmosphere setups.
- 3B Catch Tank kit.
