Different Coupe Leak Fix
  • Different Coupe Leak Fix
    Something else to try if you haven’t tried it yet.
    Ok guys. Your pleas of woe have spurred me into action. I rarely post but felt Paul N. might be near crisis point with his wet coupe.
    I spent an afternoon recently with a hose pipe, an airline and a tube of the rather sexily named ‘3M 08509’, a non hardening auto sealant.
    I had the headlining edge pulled off, loads of trim off, sunroof in bits etc.
    Surprisingly my sunroof was not leaking. I had thought it was. Luckily my windscreen area was ok also.
    The major leaks I found were getting in on both sides from under the trim arrowed in the pic and through the roof rack insert areas.
    What I did was to gun in some sealant under the trim arrowed (from the top side after drying with the airline). I also removed the roof rack inserts, squirted a bit of sealant around the holes, then replaced the inserts. Rub off the excess with a rag and job done.
    If you’re wet give it a try. Worth a try if you’re desperate I’d say. I can’t remember this particular leak being mentioned before – hence the post. Do post and let me know if it’s helped anyone.
    Nigelm
    Cheers for the advice there Nigel, I need to sort the leaky old girl out sometime, luckily I don't need her as an every day ride but might do in the not so distant future...
      I think i'm going to try that sealer on the tops of the a-pillars where mines leaking from, see if i can step the tide!
      Good tips, nice one Nigel
        where did you get the 3M 08509 from Nigel?
        I'm going to try pumping it into the tops of my a-pillar trims and see if it seals the fecker before i put the interior back in
          Brilliant post - anyone solving leaks on Coupes deserves special credit. Thanks for that - I will have to investigate on mine as it is reaching crisis point.
            Sealant
            @ Error404.
            I got the sealant from a mate who works at a bodyshop.
            I guess it's widely available. Google it?
            nigelm
              I've just orered some from here, £8 including postage
              http://www.spraygunsdirect.co.uk/pro...oducts_id=5663
                wonder what the difference between the one you list and this one...Linky
                But, isn't this just that horrible sticky black windscreen bonding adhesive - comes in a cartridge...?
                Good luck getting that neatly under the trims...!
                Chris
                  the more expensive one is for bonding in the screen, the other is a non-setting sealant that stays sticky so it doesn't dry out and crack etc
                    am at the end of my patience with mine Paul...had an inch deep in the back when i checked it on sunday...hasnt moved for over a month and is now the usual hurred up S2 that i get in november Am glad the carpet is out and very glad i hadnt put it back in. Just wish i had the time to sort mine out, its doing my head in!
                      I have this issue to deal with on the 3B i have just bought ...roof lining is soaking!! fixed a pipe on passenger side for draining but still leaking water in ..
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
                        Something I discovered that might help others.
                        My damp Coupe boot can be cured by removing the spare wheel. Not ideal if you are out and require the spare, so I carry an RAC card at all times.
                        It seems that the spare wheel distorts something at the hatch enough to let water in.
                          Well I've now had a water tight coupe for a week
                          Combination of spending hours aligning the doors, wondow mechs and rubber corner trims perfectly and gunning some of the 3M sealant listed above into the tops of the a-pillar trims and along the top of the windscreen corners. I used to have about 1/2 a litre a week coming into each footwell - now bone dry for a whole week even during the torential rain we've been having
                            Do you have to remove the trim to add sealant? I think that’s where mine is leaking from
