Vagsports / Delta Not just quattronics then
  • Vagsports / Delta Not just quattronics then
    http://audisrs.com/about9195.html%26highlight=
    The forum is littered with links from him down the years, how do these cockroaches survive?
    http://www.s2forum.com/forum/showthread.php?t=2519
    http://www.s2forum.com/forum/showthread.php?t=2577
      It could just be that not enough is mentioned about people over the years to newbie's etc?
      I'd only dealt with him thru ebay with luckily only one bad experience and only found out more when I came on this forum and read thru old posts by delta and vag-sport.
        http://www.s2forum.com/forum/showthread.php?t=30644
        http://www.s2forum.com/forum/showthread.php?t=33326
          He is active on the VEMS and motorgeek forum as well for his converted car
            Azman also bought a car that had been resprayed from him and it turned out it had been rear ended
              what is his nickname on VEMS? is that the community forum?
                http://195.159.109.134/vemsuk/forum/...=profile;u=467
                  This is him on motorgeek
                  http://www.motorgeek.com/phpBB2/viewtopic.php?t=27468
                    its a small world. somethings....namely certain individuals morals and consciences......never change. The same names banded around year after year. As Jamo posted on srs, siena predates Corey by a good few years. Its odd going on newer forums and seeing the same names popping up...and you can see how the certain individuals weedle their way into various forums/groups
                    Gav
                    S2 Cabriolet.........
                      leopard's don't change their spots, buyer beware!
                      91 Modded 3B
                      14 A6 Avant Black Edition
                        Does anyone on here remember the state the Bacofoil express came back in?
                        IIRC the oil return pipe from the turbo was bolted back on to the block with the self tappers from the front end cross member!!!
                        91 Modded 3B
                          yep, i remember seeing the pics
                            he also goes by the name of "laurence" had this guy phoning me up to discus about a v8 project he is using the same ecu as me, after having a chat with my ecu man it came aparent that this was actually siena!!!!!!
                            If anyone has bought flywheels off him, be aware that some of them have been cracking around the bolt pattern due to the wrong grade material being used, this could have very dangerous conciquences.
                            I only have this information because he "laurence" told me over the phone and couldnt understand why it was happening.
                            not slagging here just be aware of what i have heard from the horses mouth, if a flywheel lets go it is not a pretty sight.
                              he's on quite a few of the vw forums aswell now
