To kick off the new year I've just got some new parts in
I can now offer the following:-
Polyurethane Snub Bush
Machined from 90 shore polyurethane, these area serious upgrade on the OE rubber bushes (not that you can get the correct OE bush anymore ) but are a bit more compliant than delrin. I have also improved my design over exisiting bushes with the addition of retaining split pins to hold the bush securely on the snub mount bracket so it can't move. Two split pins are included.
This bush can be used with the OE bracket or with one of my aluminium solid snub brackets for a vast improvement over the OE bracket.
Aluminium Solid Snub Mount Bracket
Machined to a very high quality from aluminium and hard anodised with a beautiful black finish, these brackets are an evolution on my original design and look superb. I have been running my original bracket for 3+ years and I can assure you that the improvement in engine response and gear change will become instantly apparent with very little additional vibration or noise! (off the rubber mount). They are lightweight and allow the auxilliary rad to be retained. The mount will work perfectly with the OE bush or will provide a rock solid snub mount option with the one of the K24R poly bushes.
Solid Snub Mount Kit
Consists of 1 of each above bracket and bush, the ultimate snub mount.
£125 delivered.
£125 delivered.
