Old 29-07-10, 02:38 PM   #241
A80Avant
do you have to modify the injectors in any way?
i mean the way they sit now, are higher than normal. does that play any role?
A80Avant is offline   Post Tools
Old 29-07-10, 03:04 PM   #242
epic
epic's Avatar
No mod to injectors. Its meant to be better to have them back further in this new position.
NB: The engine mounts have both been replaced so no slack mounts etc.........
epic is offline   Post Tools
Old 29-07-10, 03:15 PM   #243
A80Avant
i have kept the original motor mounts as well, as the 034 density ones lifted the engine too high.
that photo helps a lot, so ill order the phenolic spacer from 034 then and put it in!
thanks
vasilis
Old 29-07-10, 04:30 PM   #244
Acidburn
Acidburn's Avatar
Originally Posted by Jamo View Post
You can't fit one those spacers with a reverse manifold, I tried
Would need a very small one, the ones for sale are about 8mm and too think
I remember martynf when he had one of these spacers, he tried it on the car and was experiencing problems with the earthing for the manifold, iirc its now in fitzy's garage back in the box
Audi s2 coupe, 20v Ur quattro, Vw Passat
Acidburn is offline   Post Tools
Old 30-07-10, 08:10 AM   #245
GazzaG60
GazzaG60's Avatar
im not doubting their use but personally i feel the air travels too fast into there for the heat to build significantly. ive not tested it but thats my belief.
on NA yes id think about it.
GazzaG60 is offline   Post Tools
Old 30-07-10, 09:06 AM   #246
Billman
Billman's Avatar
Audi RS2 with Holset turbo and VEMS ECU
Old 30-07-10, 09:10 AM   #247
Jamo
Moderator
Home Country - Jamaica Current Country - England
Jamo's Avatar
If the car stationary or moving at low speeds the temp in the manifold goes up a lot on a warm engine.
You can see it in a VEMS log or an aftermarket ecu log
As said though tried to fit one on my car and terrybullwons car both with reverse IM's and it put them too close to the bonnet
My car = devastating money pit of doom
Jamo is online now   Post Tools
Old 30-07-10, 12:43 PM   #248
Bram
Netherlands
Bram's Avatar
For me the spacer also did not fit in combination with the reverse IM and 034MS SD motor mounts. I was able to sell it
Stock ABY with 285HP chips, 18" Audi S8 mk1 rims, 360mm A8 brake discs, Porsche GT3 mk1 calipers, Full grey RS2 interior
Bram is offline   Post Tools
Old 30-07-10, 01:34 PM   #249
A80Avant
i have OEM motor mounts and not a stroker, so i hope i will be able to fit it in. I ordered it from 034.
My problem is apparent as jamo suggests, on traffic, very low speeds and when firing the engine after a drive from stationary. Temps for example from 13C climb to 40-60deg. on off engine, and drop to 28-30 on slow speeds before going on to motorway to bring them down thereafter.Also on long motorway cruises switching to city traffic, temps climb very easily. I wasnt aware of this with VEMS and the OEM inlet, so i believe that it could be beneficial to some extent with this setup
Old 30-07-10, 02:39 PM   #250
GazzaG60
GazzaG60's Avatar
whats the issue with those ait when idle or low cruise. will get that. the velocity of the air is too slow for the IC to work and slow enough to take on heat.
if you think thats bad. try a corrado G60.
as with lots in life its about balance and also just as important cost-benifit analysis
Old 30-07-10, 03:22 PM   #251
A80Avant
well almost 60 quid is not that bad for this.
Old 30-07-10, 03:28 PM   #252
A80Avant
within the budget limits! haha
Old 03-08-10, 09:29 PM   #253
A80Avant
a bit of work done. I resprayed the inner and outer areas of this metal tube as my mechanic back home always uses metal ends to make a lip for better hose fitment. That however means that these metal areas dont like the water injection!. So i removed the small surface rust that was building up and put it back together.!
I reinstated the second APR R1 for now as it seems to keep idle a bit better as well(or so i think. need more testing on this).
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©2003-2009 S2forum.com. All Rights Reserved.
