Ok I'm trying to setup vems on my aan. I now actually have two brand new vems ecus. Both have the same issue. Car is fine on motronic. So I swapped the red and purple wire on the crank home sensor as described on the net. The car starts fine. But between 2k and about 3.5 k rpm approx I get triggering errors. Eg the rev counter bounces about mad and I get big backfired etc. If I keep the revs up the car drives fine but between these revs its undrivable. it actually seems better with the wires as standard.
Now the funny bit. If I start the car then set secondary trigger to disabled, then disconnect the sensor the car runs fine with no trigger errors. But the car is a balls to start like this. Sometimes it does sometimes not. It always starts easy with the secondary sensor turned on.
My vems supplier is helping resolve this hence the second ecu. But anyone any thoughts. Firmware is 1.74 and I'm using vemstune. Now I use a 7a flywheel but have been told this isn't the issue as new vems is ok with that. and I have just changed the clutch this week so I don't Fancy pulling the gearbox again. The pin looks fine on the flywheel.
Cheers des.
Cheers des.
