I've had the 3 VDO auxiliary dial faces replicated in S2 grey (sorry to the RS2 boys). These can be used to replace peeling dial faces or to upgrade a set of black gauges to S2 spec. either when fitting the S2 dials or when using the black items as a replacement for damaged S2 clocks. Same high quality as the other dial faces I sell.
£29 delivered.
Or £80 for a set for all 7 dials (please state MPH or KMH).
Waste of time and money. Wrong size for my -93 white S2 gauges (too small).
wow. you think its the sellers fault that he can not see magically what size gauges you got?
pm him, im very sure he will fix it.
if not im more then happy to take it over from you, pm some photos, price, etc
Sorry you're having issues. If you return the faces then I'll happily refund you.
Unfortunately, Audi fitted several different dial clusters to the cars. The ones I sell are for the individual 52mm VDO gauges, which were fitted to the UK cars as well as many others but there are some other types. I have not had a set returned before, so the other types are arguably less common.
Please post up some pictures so I can see what's going on for future reference.
Which isn't visible in the picture or with the gauges in the car, so is a reasonable check for the future. The picture also shows that the all in one gauges are not attached with visible screws, where the individual ones are.
Annoyingly, I usually ask people to check which dials they have but that seems to have slipped through the net in this case. The same goes for people converting non S2s to S2 dials, as there are a few versions of the main dials as well.
As above, send them back and I'll refund you, or, if you can find some black individual VDO gauges to convert, then I'll give you a partial refund as a goodwill gesture.
