Avant / Rs2/ S4 rear tie rod bush
  • Avant / Rs2/ S4 rear tie rod bush
    For those that have tried recently to remove a rear tie rod on the B4 / B5 rear subframe will know that the OEM bush corrodes onto the bolt making removal or alignment a serious issue.
    Barring medieval witchcraft removal requires cutting out the bolt / tie rod in an impossible location
    I saw that :corey: a while ago had made bushes for these tie rods and KDR & VRS ( bambridge and will20v ) can now produce these bushes
    Big thanks to Kev for making these and getting them out to me so promptly
    Pictures taken from Audisrs thread, I will be putting them in brand new tierods
    This takes me up to 3 different sets of Bambridge bushes on my Avant
    bu99er i brought standard audi ones....didn't know about these....something to add to the must do list...
      I'm not going through the pain of changing corroded tie-rods again!
        tell me about it....i ended up having them hacked off and replacing the complete arm...thats how bad it got..
          doh, if i knew before...
          Audi Quattro WR
            famous last words need to do the same on the RS4, place your bets to see if they are seized or not?
            Will find out soon if not time for
              Haha, not that I should be laughing, i have the same job to do on the RS2. Reading this I'm tempted just to order new tie rods...
                I have got them via ECP and Bambridge bushes ( grabbed the last set he had on shelf ). Just need to get the bolts.
                Since everything on my car seems to be OEM it's going to be a fight I reckon
                  Are they the same on the B5 as the B4 as well? I can't find any against the B4 at ECP.
                    B4 Avant and B5 have the same rear subframe, it's why most people on here can't find them because ECP only list them against the B5
                    I'd need to get kate out to see what the part numbers are, I know I used the s4 ones via quattrocorner for the avant when I started this thread
                      Ah so the B5 S4 arm is good, like this:
                      ECP Link
                        OK, so I messed with this under the car for half an hour, I can't get it loose
                        Is this the usual problem, not even getting the inner bolt off to drop the tie rod from the subframe? Perhaps I should get a dremmel
                          there is an other thread about this on this forum, with pics about where exactly to cut and so on...
                          Audi Quattro WR
                            Get dremmel Ross, the tool of champions
                            BUT I DON'T WANT A NEW CAR!
                            1995 S2 Avant, Volcano Black
                              cut here using a reciprocating saw.
                              Audi Quattro WR
