Hi, my Aby S2 has given me 5 years of reliable joy.... until tonight
Its been running smooth, pulling strong and generally in good shape until earlier tonight i went to start it and it just turned over..... i initially thought my imobiliser fob hadnt engaged and i might have flooded her so i left it 5 mins then turned her over again and she finally started after about 5 seconds.
Incase i had run the battery down i decided to go for a drive.
Everything seemed fine until on full throttle i was only seeing a sluggish boost of 10 psi (normally 19 psi) then it returned to normal then on another full throttle was only seeing 10 psi.... after pulling away from a junction the revs slowly dropped and the engine cut out
It not spins over as if there is no compression. There was now warning noises or any noises when it cut out the cam belt is still there. Im guessing from reading old threads its most probably the 18 year old fuel pump thats failed. I had run it very low on fuel yesterday
I will try and check the pump and relay and fuses tomorrow in daylight, but is it possible to get an Aby fuel pump from German & Swedish? I cant see one listed on their website.
Any help or suggestions well appreciated, especially as its nearly ADI time
Brian
Brian
