I am looking to get a couple of catch tanks made up and so thought I'd ask if anyone else is after one as it's easier and more cost effective to get a larger batch made at once.
Please get in touch if you are interested in a catch tank. I get them all made to order now as everyone requires something a little different...
Andy, I've already got a tank that fits and will work fine, but I could do with a MkII version being made. I'll try to catch up with you sometime to show you what I need.
Pretty much. The only thing you'll need to sort is a retun to the head breather pipe.
I did a little 'fag packet' calculation.
Combe has 4 hard left corners
1 session is approx 10 laps
so that's 4 x 10 = 40 corners.
2 sessions resulted in approx. 400ml of oil in my catch tank.
2 sessions = 2 x 40 = 80 corners
so 400ml / 80 corners = 5ml / corner.
With increased boost pressure this seems to increase so I suggest a range of 5-10ml / right hand corner as a good rule of thumb.
Will be interesting to see if I can reduce this a little with an expansion can in the system.
