Following on from HPMuirt's question thread (in turn following on from ADI), I have been busy today doing some investigation into the head breather pipe as a source of oil getting into the inlet system.
Test Setup:-
The Drive:-
Results
Relevance:-
Conclusions:-
Solution:-
And finally, for those who want a laugh at my expense. When I had checked the oil level in the drinks bottle, I decided to pour the contents back into the engine. When pouring I noticed that little oil was entering the engine... I then saw a pool of oil on the inlet/injector shelf and running down the side of the engine onto the floor. I refer you to this bullet point:-
Holes + liquid =
Test Setup:-
- Firstly I disconnected my inlet return and plugged it with one of my 19mm bungs (shamless plug).
- I then set the catch tank to atmosphere through a breather filter.
- Next I disconnected the union pipe rubber joiner from the back of the head (grazed knuckles - this was a PITA!).
- I then tried to squeeze some 1/2" oil breather pipe onto the head breather outlet... it wouldn't go as it's 14mm as so much Aud stuff seems to be
- I then removed the ABY engine boost pipe...
- And then I shaved the inside of the 1/2" oil pipe, slitted it slightly and beasted it on - not much fun with the access I had and worse on a stock car!
- Finally I plugged the union pipe rubber joiner so that the block was breathing through only the catch tank - avoiding too much oil going where I didn't want it to!
- I then took a 500ml drinks bottle and cut holes at the top to allow it to breathe.
- I then fed the end of the oil hose (connected at the other end to the head breather outlet) into the drinks bottle and sealed it on with tape.
- I refitted everything, checked it all and went for a drive...
The Drive:-
- Firstly I trundled along to get the car up to temperature and to get to some 50/60 mph roads.
- Just before I joined the fast roads, I pulled over and checked - no oil in the drinks bottle.
- I then joined the road and accelerated hard in 1st and 2nd gear.
- 2nd in my car is ~0.5g (30-60mph = 3s).
- I managed to do 3 2nd gear runs and 1 rolling 1st gear run (~0.75g)
- I pulled over and checked the drinks bottle
- A small amount of oil was in the bottle.
- Again, a mixture of 1st, 2nd and 1st-2nd runs, no more than 5.
- 3rd wasn't really an option but I did touch it for 1-2s on a couple of occasions.
- I then pulled over and checked again, more thoroughly
- ~50ml oil in the drinks bottle!
Results
- 50ml of oil left the head breather after ~10 0.5g runs of 3 seconds each.
Relevance:-
- My car is fast for a stock car as it's got various lightwight spinning bits and is stripped of 75kg at the mo so I am confident that my results cover stock S2, chipped S2, stock RS2, mildly chipped RS2, S2 small hybrid.
- They can also be assumed for any car running 0.5g in the higher gears but for these cars the higher boost could mean higher crank case pressures due to blow by etc. There is also the question, how much oil is there to actually move?
- The results are for a straight line on level ground and do not take into account slopes or hard cornering effects.
Conclusions:-
- The amount of oil leaving the head breather is enough that it needs to be dealt with properly if using an S2 on track.
- For a road car running chipped RS2 spec or less and with the stock 14mm pipe leading from the head to the block, the breather system will cope OK under most conditions, a stock catch tank will help here but must not take a separate head feed without a wet sump return.
- Equally, for an occasional track car of chipped RS2 spec or less, again, a stock tank will work OK here with the same condition as above, just remember to empty the tank and that whever is in the tank isn't in the engine so if you're filling a 1 litre tank then that's bad m'kay!
- For higher powered cars capable of sustained 0.5g acceleration, the system will start to be overwhelmed and must be replaced.
- For all cars, hard acceleration under high right hander cornering load will overwhelm the system, luckily this is brief in most cases so can be managed.
Solution:-
- Non standard head breaher position.
- Baffles added to head breather.
- Swirl pot in the oil breather system will help.
- This can be replicated by a properly plumbed-in catch tank.
- < Chipped RS2 - wet sump return optional.
- > Chipped RS2 - wet sump return essential.
- For the standard oil system there are no effective solutions, only management using one of the above items and manual checking / emptying of any tank in the system.
Originally posted by rusty
