Does anyone have a 16point plotted curve for the 1.8T IAT sensor or the CLT sensor used by our engines with VEMS ?
i use succesfully from marc the 2252/256 (IAT) and 1900/256 (CLT) patches, but i must say i get some odd differences on the readings when compared to the car's sensors.
thanks to thomas i now have the CLT oem audi sensor curve so that will work.its the same sensor for all audi I5s
i will buy a K type sensor to check the 1.8T sensor curve with the multimeter and report back. as there are a few of us using it, it will be more accurate than the patches.
It was just a question because on the 034 motorsport website it says that the item can be used for the 3B, but it does also say that it cannot be used with motronic, so this item would be no use for a direct replacement?
here is what the sites says: Can also be used on older Audi AAN/3B applications with the center hole slightly enlarged., but not electrically compatible with the factory Motronic engine management.
I have one on my 3B engine and am having problems with it when I Vagcom the car. It says: Intake Air Temp Sensor, G42 - Open or Short to B+ Is this going to be likely because the sensor is not compatible with motronic or bad wiring, I asked before and they said the reason it is not compatible with motronic was due to the connectors.
