Question : How does this conversion sound.
Caliper : Twin pot from a 1996 Audi A8
Disc : Merc 345mm X 32MM . weight 12Kgs
Thinking about an upgrade on my S2 and S2\V8 projects.
Here are the details on the S2:
Originally tried a Merc E500 W211 four pot caliper but the mounting lugs where too close to the original mounting points on the strut. Same Problem with A8 disc and calipers on the S2 strut.
Then hit on the idea of the Merc discs with the A8 calipers. Because of the larger dia. the caliper is moved away from the strut making it easy to make up an adapter.
Fits in a 17" wheel both in dia and offset. Only machining required on disc is to bore out the center of the disc by 1mm to fit the Audi hub.
Only thing that worries me is that this will be a big increase in unsprung weight.
Here are some pics.
Other thing is pads will have to be made as they are not available in South Africa other than from the agents and that's at a ridiculous price.
Here are some pics.
