I really need to refresh my 6 speed linkage, the ball and socket is like a prick in a bucket.
Anybody know where to get new bushes, (OEM or aftermarket is fine)
If this is something that isn't readily available, i wonder if Rusty or Bambridge has looked into it??
Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold 03 Dolphin B6 S4 Avant LPG - New Daily Wagon
01 Silver D2 A8 3.7 quattro sport - SOLD
Ahh, i should have specified, its the ball and socket linkage joint on the gearbox thats sloppy, not the one on the transmission tunnel. I already have a B5 S4 short shifter kit ready to fit.
Thanks anyway though
+1, my linkage will be out and at the moment I'm looking at OEM new replacement for £300+ and a terrybulwon bush, or hopefully can find a replacement balljoint used or custom new. I'll document whatever I do but it won't be for 2 weeks...
Get some pics of the linkage up and we'll see what sort of thing might work Not seen what Terry has done, I'm sure it'll be in his build thread though.
I have a uniball in mine, same as James one. It required a fair bit of fettling to get it to work as the uniball is at its limits of movement in order to select every gear, ideally you would use a high-misalignment joint, or a bigger joint but neither will fit into the machined ball joint cup on the linkage - or you could machine up a bigger cup to receive a larger joint. IIRC James said he cut the ball joint cup off the linkage to machine it to accept the uniball, and used mine as a jig to re-weld it back together afterwards, and even then I had to bend mine a fair bit to make it work, but its great now and ZERO slack in it.
Its do-able but not as easy as it sounds. An easier solution would be a custom nylon bush to replace the knackered one in the linkage.
How would I go about getting a custom nylon bush made up? I'd be happy to get a batch of 10-20 done in one go, I'm sure there would be enough demand to recoup the costs.
Spink has one for sale, maybe he would lend it to you for a few days so you could take some measurements off it. I'm sure that if you and Kev could come up with a replacement socket there would be a huge demand for it.
Hello.
I must take some pics but I just mount one from a S4 sedan TDI and only one problem if I mount that, the second gear.
But if I will change one piece, the piece that U must mount on a 034MS shortshift, the problem desappear.
PS: I broken completely my linkage and I would come back at home with only 5 gears and puting they very slowly.
BUT, how can my car runs on 5th gear
A rose jointed linkage is not plug and play. I done Alex's as a favour for using his as a jig and its well over £150's worth of work before parts.
If any one wants a rose jointed linkage i will happily copy mine but your looking at £250 ball park. I have given the cup and ball to a nylon bush company to see if they can help, i'll chase them next week i must have had 20 PM's regarding this but work is dictating my life at the minute.
I told you mate, i've got a spare rear half of the linkage sitting around in good condition.
I think a replacement nylon bush is the way forward, and like others have said, i think there is definitely the demand for it if it is reasonably priced, combined with James's other linkage bush could be a complete linkage refresh kit.!
