Electrolysis subframe rust removal
  • Electrolysis subframe rust removal
    After experimenting with electrolysis rust removal on small front suspension parts I wanted to try it out on something bigger. I didnt have any container big enough for my subframe but I had a few blocks and an old rideon mower cover.
    Just water, 600g of baking soda, 12V from battery charger, some cheap jumper cables, negative to subframe and positive to an old sacrificial chainsaw bar.
    Within minutes the bar started to fizz. Current draw was never more than 2A
    After 4hrs rust sediment was visible.
    How the subframe looked before I started.
    Subframe after 1 day
    Subframe after 2 days, I just power washed it to wash off the flakes of rust. Current draw had dropped way down to a point that could not be read.
    While the subframe was doing its thing, got time to work on other parts.
    Small tank.
    Diff-Lock Actuator guard: Before
    Diff-Lock Actuator guard: After 2 hrs
    Rear ties, the both pretty much looked like this.
    Half not done, Half done
    After 4 hours
    All cleaned up.
    Eric
    95 S2 Avant under rebuild.
    Sweet, good job!
    Might have to try this electrollylark.
    1993 ABY Coupe | BMW R1200 GS
    A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
      Very nice result. I must try it too someday.
        interesting stuff....might be a good alternative. what sort of rust protection does this give once completed?
          None, it can rust again quite quickly if you dont treat it. You will get surface rust in a matter of hours if you dont protect it. In my case I used a rust preventer and then por15. But use can use POR15's own metal ready and then paint. Its up to you. When I did my suspension bits I coated them with wd40 to prevent rust until I was ready to paint, once I opened a POR15 can I wanted to paint as much as possible.
          Eric
            You can also reverse the process using sacrificial old copper pipe and effectively copper plate components (* i wonder if you could effectively thinly galvanise items using something zinc??*)
            Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
            03 Dolphin B6 S4 Avant LPG - New Daily Wagon
            01 Silver D2 A8 3.7 quattro sport - SOLD
            "Difficult is worth doing"
              Really useful to see this in action - I've an old petrol tank I've been thinking about doing this to so it's great to see that it works so well.
              John
                Thanks for sharing, that looks like fun.
                Shane
                  Genius!
                    Great process- did my HP2s a while ago.
                    Thread here:-
                    http://www.s2forum.com/forum/showthr...r+electrolysis
                      copper plate? Does it work just like this? Any pictures before after?
                      Go Holset or Go RS4
                        thermal coating
                        Great job on subframe .I came across a new process instead of galvanising called thermal coating where a company near to me sand blast then thermal coat with zinq (no heat hence no warping) then apply 2 coats of powder coat Great job and they say its better than galvanising susposed to last up to 25years and its cheaper than galv as i get gates and rails that i make done. Example full set of gates 3.5m by 2m set cost me £135 complete .I'm ready to take up a set of H&r springs to have it done so will keep all posted on the result and price.:thumbs :http://www.youtube.com/watch?feature...&v=uV-QPTpJaYo
                        watch this video
                          Thread here:-
                          Indeed, it was your thread and this one
                          http://www.s2forum.com/forum/showthr...t=29723&page=5
                          I never thought of using this process on car stuff until I saw it posted here.
                          Eric
                            cool!
                            would this work or is there a similar process for corroded aluminum?
                            Justin
                            1990 Audi Coupe Quattro= http://www.s2forum.com/forum/showthread.php?t=46309
                            1991 Audi 200 20VTQA= http://www.s2forum.com/forum/showthread.php?t=54410
                            1987 Audi Coupe GT
                              As far as I know, It can work for aluminium but you have to be very careful, the electrolysis reaction doesnt stop with the corrosion, it can take good material too, so work in short intervals like every 10mins and clean it to see how it goes.
                              Also ****DO NOT USE STAINLESS STEEL ***** as sacrificial material, it can release toxic chemicals.
                              Eric
