Right, this is now going to be a combined advert for parts I have left, I am going to ask the mods to delete the older ones but until then please do not ask for parts which you may of seen on old adverts as chances are I don't have them still
The parts below are in no particular order, I was going to Ebay everything but for now I'll list them on here, over the course of the next month I will start listing the parts on Ebay but for now I'd rather offer them out on here.
ABY Avant
ABY engine, 128k, FSH. I have driven this for nearly 700 miles and its great, quiet and pulls nicely. Complete with turbo, WG, inlet, alternator, starter, no loom or ecu etc. I don't want it sat around for ages so £900
ABY Ecu, totally standard £150 SOLD
ABY Ecu, chipped to 280hp, 28mpg, not homefries. £225
ABY MAF, perfect £50
6 speed gearbox, shifts perfectly, NON CGR no whines in any gear £275
6 speed gearbox, has diff whine, works perfectly though, NON CGR £100 SOLD
6 speed gearbox mounts £100 SOLD
ABY Intercooler and crossmember £90 ( slight dent in bottom of IC )
Rear diff, £50
Front bumper in green, has splits on the underside, has been repaired poorly but isn't that noticeable, needs painting. has all grills, no lights or indicators £100
Front bumper in red, tidy, could do with a good polish, has all grills £175 SOLD
Indicators and lights for above, will not split until bumpers are sold, can do a deal on either bumper with these.
Outer rear lights, £20 the pair SOLD
Inner rear lights, £10 the pair SOLD
Number plate panel, £5
Electric window winders £10 each ( I have several for every door )
Hydro door lock mechanisms £5 ( I have several for every door )
Air pump £15 ( from boot )
6 speed front subframe, needs refurb £35
Cast front wishbones, £60
Upper rear wishbones £20
Brake bomb £30
Rear discs and calipers £50
Propshaft £40
Battery cable £25
Turbo/MAF intake hose, includes dump valve £15
Lower boost hose £20
Upper boost hose £15
High pressure steering hose £10
High pressure brake bomb hose £10
Water hoses, I have most hoses, just ask.
POS sensors with bracket £40 SOLD
Lambda sensor, various, all working £10 each
Fuse board with fuses and relays £25
Complete sunroof assembly, inc motor £30 various colours
Front wiper motor x3 £10
Radiator fan unit £20
Centre console with diff lock switch £15
Dashboard undertray £10
3 spoke steering wheel with correct cowling for non airbag wheel, has the very slightest bit of wear on one part at the top but hardly noticeable. Cowling has a LED fitted in the top section for a immobilizer. £80 SOLD
Stalks with computer control, perfect working order, I've even cleaned off the usual grime off the stalks so they are exceptionally clean. £30
3B Coupe
Ecu, MTM chipset, 270hp £225 SOLD
5 speed gearbox, brand new Audi slave cylinder, £75
5 speed subframe, VGC £40
Rear bumper, has a few marks on it but otherwise fine, £40
Rear lights, £20 the pair
Number plate panel, £10
Electric window winders, drivers and passenger £15 each
Hydro door lock mechanisms, driver and passenger £5 each
Rear brake calipers £25
Propshaft £40
Steering rack, no arms £30
3B engine loom £30 SOLD
More parts to follow, I will upload pics on request although everything is in working condition, if something was even slightly broken it went in the bin.
Most parts sent within the UK can be sent with a 24 hour courier, large heavy items can be sent on a pallet worldwide for sensible costs, I only charge what I get charged plus a bit for the wrapping which I hope most will agree is usually more than adequate
ABY Avant
Rear diff, £50
Brake bomb £30
Propshaft £40
Battery cable £25
3B Coupe
Propshaft £40
