S2 front hubs. Back plates are bent and useless but the actual hubs and bearings are good:
£120 posted.
Front driveshafts from a 7A engined coupe. Ideal for the 5 stud conversion:
£35 delivered
Genuine 314mm discs:
Tax disc not included.... £70 delivered.
Genuine (A6 rear) brake hoses and carrier>hub bolts. Required for 5 stud 314mm convesion:
£35 delivered.
Pair of front ATE 57 caliper and correct carriers for the big break conversion:
Ignore the one that looks shot, it was, and was replaced with a VGC used unit. Both caliper pistons move freely and are in very good condition. £150 posted.
Complete early A4 rear brake set-up. Includes every nut and bolt required (bearings, clips, abs rings, disks and pads) to bolt onto a FWD coupe to convert to 5 stud:
£75 posted.
I'm open to sensible offers on the parts and would do bulk discounts if you want to buy multiple things. I have literally everything for the conversion except the front pads, so someone could save themselves a lot of work!
Items can be collected from Aberdeen, Scotland, if you want to save on postage.
Any additional info or pics available on request. I have a list of all part numbers somewhere.
£120 posted.
£35 delivered
£35 delivered.
£75 posted.
