Best place to buy F5DPOR's
This is a sticky topic.
  • Best place to buy F5DPOR's
    Pricing all over the shop online - any tips? Just seen £16+vat per plug
    Sure it wasnt that long ago I bought 5 for £35
    Main dealer only imo. Less likely to get a duff batch.
    Alternativelly you could buy NGK BKR-7EIX. Which is a cheap alternative.
    UrS6 Stroker + HTA3586 =
      My dealer set at €85 have caused no end of damage when the core fell out one. New block req.
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
        I'm very unhappy with those. Brand new plugs and the car misfired on dyno runs. Now I'm with champion QC59C - very happy
        For such high price they're very poor made....
          Take it back guess the dealer ones are as bad as everywhere else now
            how can they be so poor - getting kicked round the stockroom or something???
              I have used these plug for years in a few setups and never had a issue.
              Last time i bought the F5 DPOR plugs think it was ebay.
              Craig
              Audi A6 AEL 5cyl Quattro breaking.
              Audi A5 3.0tdi Quattro Stage 2
              07947385043
                http://www.ebay.co.uk/itm/Bosch-Plat...item2311eba21c
                07947385043
                  Ask for discount on postage.
                  07947385043
                    Don't buy these plugs anymore. They moved their manufacturing into a chinese ghetto or something...
                    The porcelain bits break and fall into the cylinder, causing damage, brand new plugs misfire sometimes for no reason at all, etc.
                    I use FR5DP's from Volvos and I never had a problem with those.
                      Yes, FR5DP is actually one of the best choice to use with 1.8T coils. So If you have done a coilswap these will work great, and cost the half of the F5DP0R.
                        I stand corrected
                        07947385043
                          Originally posted by K7ERG View Post
                          I stand corrected
                          The problem happened fairly recently. Like they started getting worse 1 year ago or so.
                          It's like buying a lottery ticket nowadays. If you are lucky, all will be fine, if you are unlucky, you'll get engine damage because of broken porcelain.
                            http://www.ebay.co.uk/itm/1x-Bosch-P...item3371bc839d
                            07947385043
                              So are the FR5DP's also suitable for the stock coils, or do you need the 1.8T coils?
                              Put new POR's 1year and a few months ago, so don't want te be running any risk.
