Breaking urS4 all parts available
  • Breaking urS4 all parts available
    1992 Avant, 185k miles
    6 speed gearbox, no unusual noises. €250.
    Locking rear diff (needs oil seals but lock mechanism working fine) €200
    Front Drive Shafts €50 each
    Rear Drive Shafts €50 each
    Rear Shock & Spring Assemblies €50
    Front Subframe €50
    Front ARB €50
    AAN Water Manifold €50
    AAN Fuel Rail incl Injectors and incl FPR €150
    AAN Intake Manifold €100
    AAN Throttle Body €50
    MAF €50
    Airbox €30
    K&N Filter €20
    ABY Airbox €50
    Radiator €50
    Oil Cooler €50
    Metal mounting for cooler is rotten free to good home
    Plastic Duct perfect €10
    The pipe that connects to the rear of the cooler is still there €20
    AAN Downpipe €80 (Lambda sensor is no longer fitted)
    Exhaust without Cats €50 (open to offers)
    Fuel Tank €100
    ABS Valve €50
    ABS ECU €50
    Variable height bonnet lifter €50
    All electric windows working regulators €50 each
    2 good front seats €80 the pair
    Complete set of door locks (5x) and ignition and key €150
    All glass available.
    Avant rear door with "quattro" script defrost glass €50
    Boot Gas Struts (pair) €50
    4 other doors €50 each
    Bonnet €50
    Rear Bumper €50
    Front Bumper €50
    4 Door cards €100
    Drivers, Passenger & Rear Seats €120
    Funky Head rest things €100
    Set of internal grab handles and lights (4x) €50
    Front internal light & sunroof controller €20
    Rear internal light €20
    Luggage cover €70
    Any other parts just ask.
    All prices are excluding transport, parts are located in Ireland.
    Open to offers on multiple items.
    These parts are not available:
    6 Speed Linkage
    Engine Block & Head are being kept, ancillaries available.
    ECU
    Lambda Sensor
    Catalytic Converters
    Instrument Cluster
    Front Lights
    Number plate holder
    Rear Tail Lamps (Left & Right)
    Trim around the climate control console
    Ashtray
    Front HP2 struts and brakes
    Wheels
    Rear Axle Cross Member & ARB
    ABS sensors all gone
    Rear Hubs & Brakes
    Shane
    Photos of body panels etc (no extra charge for cobwebs):
    Shane
      what milage im just curious..
      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
        Interior Photos:
        4 x interior lights
        There's a pair of front fitted mats there too:
        Shane
          Can you send me a PM with HP2 setup please? What is included? calipers, discs and struts?
            Is the gearbox same as an S2 box?
            ABY S2 stroker (work in progress)
            B5 1.8T quattro
            B4 2.3 (decommissioned)
              Do you have rhe pos bracket?shipping to madrid (spain)??
                Sent
                Should be the same.
                If I have this part left over I'll send you a pm
                Shane
                  breaking
                  Interested in the rear brake calipers and discs. Brian
                    185k miles, added to the 1st post
                    Pm heading your direction now.
                    Shane
                      Engine Photos
                      Shane
                        Lights & Mirrors Available:
                        Shane
                          Front ARB available:
                          Shane
                            Rear Shocks & Springs Available:
                            Shane
                              Shane
